whats a power wire?
Old Feb 7, 2010 | 02:10 PM
  #21
cwboyjohnny24's Avatar
cwboyjohnny24
Originally Posted by weedahoe
Take both ends of the resistors and fold them back in half
Sorry weed, for asking all the questions brother, I'm just really interested in this one. What do you mean with folding the resistors in half?
Old Feb 7, 2010 | 02:12 PM
  #22
tuned93's Avatar
tuned93
cuz the ends of the resistors are soo long and thin, you fold them in half so the crimp can clamp down on them and they wont slide out
Old Feb 7, 2010 | 02:45 PM
  #23
BadHab1t's Avatar
BadHab1t
no it does not matter which one you cut it just runs in a loop....
Old Feb 7, 2010 | 04:22 PM
  #24
tuned93's Avatar
tuned93
so i saw on oklahemi's write up he used 4.7k-Ohm resistors. 1/4 watt, 5% tolerance. i just ran out to radio shack and got some resistors, but they ar 47k-Ohm. 1/2 watt, 5% tolerance. will they work or should i get something different?
Old Feb 7, 2010 | 05:21 PM
  #25
canadianbrute's Avatar
canadianbrute
I live in canada. it already is 20 degrees cooler here. would i see any gains from this mod?
Old Feb 7, 2010 | 06:53 PM
  #26
weedahoe's Avatar
weedahoe
Hall of Fame Member
1/2 watts wont make a difference. 4.7k's trick the PCM into thinking the incoming air is 22* cooler. But it will only go so low before the PCM takes over and corrects itself. So if its 50* outside, dont think the PCM will let it think it is 50*-22*
This is a pic of mine I did some time back. Tuned has it right on why you should bend the resistor wires in half.
Old Feb 7, 2010 | 08:31 PM
  #27
rtmtrrdr's Avatar
rtmtrrdr
wow you guys pulled up one of my REAL old threads didn't you?
Old Feb 7, 2010 | 09:06 PM
  #28
tuned93's Avatar
tuned93
So I should use a 4.7k 1/4 wt instead of a 47k 1/2 wt?
Old Feb 7, 2010 | 09:17 PM
  #29
cwboyjohnny24
I'm guessing it won't make a difference.
Old Feb 7, 2010 | 09:42 PM
  #30
Desert_Ram's Avatar
Desert_Ram
rtmtrrdr haha that was me dont know how i came across it but had a few questions?
