Lamp out? WTF?
Old May 25, 2008 | 09:19 PM
Bucky's Avatar
Bucky
Default Lamp out? WTF?
My "Lamp Out" warning light went off in my 04 SLT, and I replaced the only bulb that was out. The light is still on. Any Ideas why?
Old May 25, 2008 | 09:31 PM
Parts/Service's Avatar
Parts/Service
Default RE: Lamp out? WTF?
This model is known for having problems with the tail light strip (bulb holder). You may need to replace it...
Old May 26, 2008 | 04:21 PM
Bucky's Avatar
Bucky
You mean all of the bulbs or the taillight assembly?
Old May 26, 2008 | 04:56 PM
jstmahoney's Avatar
jstmahoney
I think David means the tail light strip. I know other people have had this problem with the "light out" and in the past I have had it come on and a few days later another bulbwent out. But before you go get a new tail light strip, make sure the blubs are pluged in all the way and make sure your signal, brake, and back up lights are working. Just my $.02.
Old May 26, 2008 | 06:17 PM
occ3377's Avatar
occ3377
and your license plate illuminators
Old May 26, 2008 | 06:36 PM
tamuccmike's Avatar
tamuccmike
Mine did this...you check the break light? have someone hit the breaks and check it
Old May 26, 2008 | 07:31 PM
kenihemi's Avatar
kenihemi
Why the WTF?
You have a problem? we will help. No need to act 14 years old.
Old May 26, 2008 | 07:59 PM
Rampower's Avatar
Rampower
Had the same problem... replace the socket assembly. scrap yard, cheaper.
Old May 26, 2008 | 11:57 PM
dodge it then ram it's Avatar
I had this prob. It was just a tail light that went out. Fixed it in 5 minutes. No biggie.
Old May 27, 2008 | 08:02 AM
Hemichief's Avatar
Hemichief
I had the same issue on my 03 - it was the upper bulb in the rear light. After changing it 2 times, the dealer noted that possibly the strip was shorting somewhere. They replaced it and I have not had any issues since then.
Good luck to you.
