SUPERCHARGER INSTALLED!!!!!
Old May 30, 2008 | 01:34 PM
atlaticblueram's Avatar
atlaticblueram
Default SUPERCHARGER INSTALLED!!!!!
I finally installed my supercharger again and it looks great just thought i would post some pics of it!!!
Old May 30, 2008 | 01:42 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Default RE: SUPERCHARGER INSTALLED!!!!!
why did you take it off?
Old May 30, 2008 | 01:51 PM
atlaticblueram
i just bought it two weeks ago but i took it off right after i bought it because the serpentine belt i had originally was a half inch to long and the belt would slip @ 3lbs of boost so i took it off so icould drive it to work. just put it back on last night with the right belt and am now running 9lbs of boost but i am getting spark knock @ 8lbs so i am replacing the fuel injectors with ford motorsports 24lb and hour injectors this weekend and throwing a MSD 6AL ignition with blaster 2 coil and 8mm plug wires. Might even send PCM out to KRC performance to have it tune a little!!
Old May 30, 2008 | 02:09 PM
kenihemi's Avatar
kenihemi
What A/F are you getting under boost and WOT?
Old May 30, 2008 | 02:12 PM
xfeejayx's Avatar
xfeejayx
kickin ***. glad to hear it's working for you. thought of getting an aftercooler?
Old May 30, 2008 | 02:23 PM
thehemiman12345's Avatar
thehemiman12345
9 pounds....sweet....Does anyone know how much the hemis can take before you have to start digging into them?....
Old May 30, 2008 | 02:44 PM
atlaticblueram
my 5.9 should not be getting 9lbs i am changing the pulley tonite. stock internals at 9lbs of boost blow the head gaskets real quick! As far as a/f not sure if the bigger injectors take care of the spark knock i wont send the computer out but if it doesnt i have to send it out for the timing curve to be adjusted.
Old May 30, 2008 | 03:26 PM
motorider228's Avatar
motorider228
ORIGINAL: thehemiman12345
I have heard 7 pounds is about the highest number on a stock 5.7 liter. I'm not sure about the crank and rods and all that but I know we have pretty weak pistons.
