Everyone idle high at startup?
Old Jun 10, 2008 | 12:42 PM
kenihemi's Avatar
kenihemi
Default RE: Everyone idle high at startup?
I know your forever was a way of saying a long time.
But does it as long when its really warmed up as it does starting cold?
Old Jun 10, 2008 | 09:45 PM
04 HEMI 04's Avatar
04 HEMI 04
my truck starts at 2000 then lowers to 1400 rpm and drop 100 rpm per sconds till around 500 rpms
Old Jun 10, 2008 | 11:11 PM
Foiled's Avatar
Foiled
900 rpms is all i get at start up. Then it lowers to 400 rpms after a few secs
Old Jun 11, 2008 | 12:48 AM
RamItOne's Avatar
RamItOne
it should be at 700 rpm.
High idle is something the ctds can modify.
Old Jun 12, 2008 | 07:43 AM
#Red's Avatar
#Red
I have the exact same issue. I asked that question here a while ago and everyone told me it was normal and to live with it. Mine takes about 45 seconds to drop to 700 RPM. Is it normal or is there an issue here? Thanks. Red
Old Jun 12, 2008 | 08:14 AM
JRam08's Avatar
JRam08
My 08 Hemi does the same thing startup hits about 1400-1500 RPMs then it goes down after about 20-30 secs. Never really timed it out. It has done this since new and now has 4k on it.
Old Jun 12, 2008 | 01:31 PM
Foiled's Avatar
Foiled
I wish mine would idle at 700rpm. Many times I have been backing the boat up and have to cut the wheel hard and quick and the engine would die if I hit limit of my wheel too hard.
I can make my engine die anytime. All I have to do is let the engine idle then turn the wheel all the way left or right and then push a little harder then it dies.
Old Jun 12, 2008 | 07:30 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
normal..
Old Jun 12, 2008 | 07:45 PM
a4twenty's Avatar
a4twenty
ORIGINAL: Foiled
not sure what is worse, that this is happening or that you haven't just taken it in under warranty....................
mine idles high to at start up ( regardless of engine temp ), feel kinda silly sitting at the gas station idling till it drops but............ what can ya do.
Old Jun 12, 2008 | 09:02 PM
RamItOne's Avatar
RamItOne
Yall may want to run 0W oil so it gets in the engine quicker so those higher rpms don't cause too much metal on metal
