Interior lights shutting off too soon
For several months now I've had a problem where the interior lights will shut off after exactly 15 seconds, and without the normal fade out. If I hit the lock/unlock switch, open/shut a door, they will come back on only to off after another 15 sec. Anyone else have this problem?
Thanks!
Thanks!
mine shut off like that too but if i actually need them for any reason i can just tap on the overhead console lights and they come back on and stay on. no problem there. maybe i am missing something though?
I disconnected one terminal from the battery for a few seconds and then reconnected it.
With the front drivers door open, I waited several minutes and the interior lights stayed on.
I suppose they will turn off after 10 minutes per the owners manual.
After doing some ressearch online, this seems to be a common problem with the 2006 RAM.
My '06 used to do the same thing. I did the battery disconnect thing for a few minutes, and it has been fine ever since.
Trending Topics
there may be a flash the helps with the interior lights turning off to soon with the door open
you can not increase interior time on with the star scan but you can change headlamp delay or how long you radio stays on after you turn off the key the interior lights are controlled by the ccn (cluster)
