Zero Weight Oil
Old Jun 21, 2008 | 07:24 PM
LoFlyer's Avatar
LoFlyer
Default Zero Weight Oil
I've been using 0W20 oil for the past month and have improved mileage by .6 mpg. I didn't think it would make any difference but it has consistently improved my mileage for the past 1500 miles. Bottle says that it meets specs for 5W20. Just thought I'd let everyone know.
Old Jun 21, 2008 | 08:03 PM
sos's Avatar
sos
Default RE: Zero Weight Oil
What brand?
Old Jun 21, 2008 | 09:04 PM
whiteonrice's Avatar
whiteonrice
??? brand
Old Jun 21, 2008 | 10:10 PM
lxman1's Avatar
lxman1
Site Moderator
Thinner oil is easier for the oil pump to push so it's less drag on the engine.
Probably Mobil 1.
Old Jun 21, 2008 | 11:01 PM
butch1581's Avatar
butch1581
any negative effects of using the oil. I saw the mobile 1 0W next to the 5w when I bought mine, and was wondering about it.
Old Jun 21, 2008 | 11:45 PM
lxman1's Avatar
lxman1
Site Moderator
I think Mercedes uses it in their European models. It doesn't usually get as hot over there. I'll stick with 5W20 myself. That's thin enough.
Old Jun 22, 2008 | 03:31 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
lots of engines use 0 weight oil now. its not smart to do if your engine manufacturer doesn't recommend it.
Old Jun 22, 2008 | 08:09 AM
LoFlyer's Avatar
LoFlyer
Brand is Mobil 1, though I know Amsoil makes it also. Advance Auto is having an oil change special with 5 qts of Mobil 1 and a Mobil 1 filter for $27. I agree with concerns over viscosity, I'm going to research this more. One other thing I've noticed; it take longer for the truck to get to normal operating temp with the zero weight. I'm hoping this is because of reduced friction.
Old Jun 22, 2008 | 10:50 AM
jonnymagnum's Avatar
jonnymagnum
I changed my oil acouple weeks ago with castrol GTX syntec 10w30. do you think thats too thick?
Old Jun 22, 2008 | 12:48 PM
xfeejayx's Avatar
xfeejayx
thicker than you need it, but nothing at all to worry about. I think the Hemis are specd for 5W30, so you at least got the 30 part right. remember the W part is the cold rating, with it getting warmer out now you will be absolutely fine. I wouldn't do that in the dead of winter, but i bet it still wouldn't have problems.
