H.I.D problem (not flickering problem)
So i recently put in H.I.D. headlight in my 05 ram, they work and everything with out the flickering problem because the company i bought them from sent me a harness so that wouldnt happen, but what is going on now is , i go to my truck put the headlights on regular and nothing happens, oncei hit the hi beams the HID hi beams go on then i will be able to use the LO HID's from then on, also when i start my truck up the lamp out does flash untill i flash the hi beams to get to my low beams then everything is perfectly fine from there. also after i use the headlight i will be able to use switch like normal with the lo's but then after a little bit only one will come on then eventually they will not work uintill i hit the high beam again, also there is a loud humm when on high beam
HELP ME OUT!
HELP ME OUT!
