Ram 1500 Hemi towing another vehicle???
Old Jun 28, 2008 | 11:53 PM
cazador223's Avatar
cazador223
Default Ram 1500 Hemi towing another vehicle???
I want to tow my 95 Silverado (4 wheels on the ground ) with my 06 Ram QC Hemi, total trip will be about 1600 mi. There will be 2 of us and I plan on driving the Chevy up any steep grades or hills, the gross weight of the chevy is 6K, Can the Ram handle the job?
Thanks
Tom
Old Jun 28, 2008 | 11:56 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Ram 1500 Hemi towing another vehicle???
no problem....i pulled my 90 ramcharger (gross weight is 6K) and it did fine.....pulled a 16 V-nose that when loaded weighed in at around 7K and had no problems.....she'll be fine
Old Jun 29, 2008 | 12:05 AM
John  M's Avatar
John M
Towing 6k lbs is no problem. Towing any vehicle while all 4 wheels are on the ground is much more involved. You see it done behind campers but I've never seen it in any other case. You have some sort of tow bar arrangement?
If you don't disconnect your Chevy's driveshaft (or shift the Tcase into neutral if it's 4x4), you'll run the risk of burning up its transmission. Assuming your Silverado is extended cab 4x4, it's too heavy for UHaul's trailer. The only configuration they can handle is a 2wd regular cab.
FWIW, I towed a 6k lb combined load (Grand Marquis on UHaul trailer) with my 1992 GMC extd cab 4x4 with the TBI 350, no problems at all. My current truck has twice the power it did so it'd be a piece of cake to tow only 6k lbs.
Old Jun 29, 2008 | 03:41 AM
mustang_170556's Avatar
mustang_170556
6k will be nothing for your truck. i towed a 9k trailor accross ohio with no problem at all. that's a stock hemi 1500. i even stopped on a really steep hill with the trailor just to see how well it took off. it did everything but spin the tires.
Old Jun 29, 2008 | 07:11 AM
lxman1's Avatar
lxman1
Site Moderator
Stopping would be my concern. I would find a trailer with brakes to be safe.
Old Jun 29, 2008 | 12:21 PM
cazador223's Avatar
cazador223
I plan on using a tow bar, also it is 4WD.
I had origionally planned to usea trailerbutit would be too expensivefor 18 days, it would be cheaper to just have someone else just drive the truck.
Thanks for the replys and advise
Tom
