Is this for real?
Old Jun 29, 2008 | 09:11 PM
8t5gt's Avatar
8t5gt
Default RE: Is this for real?
ORIGINAL: epegasus
Yeah, I noticed that but the problem is you really don't want a heated mixture going into the engine.
Think about this. Spark plugs supply a plasma like heat to the fuel mixture to explode it. This system will simply cause the mixture to explode before it is where it needs to be in order to move the piston. I did the rough math and figured out that even very inefficient engines still burn over 85% of the fuel mixture in the cylinders. The remaining 15% is not enough to give a 50% increase in mileage.
i think its crap but about your math, their adding water to the gas to diloute it ., so the added water would make their more for the engine to burn would it not ?
Old Jun 30, 2008 | 12:43 AM
lxman1's Avatar
lxman1
Site Moderator
Looks like a fancy way of doing the old JCWhitney magnet around the gasline to me!!! Won't work.
Old Jun 30, 2008 | 08:24 AM
epegasus's Avatar
epegasus
Water injection is a trick used by the forced injection crowd to fight pre-detonation. With this gas saver product being used on a naturally aspirated engine the only benefit would be a bit of cooling but that would only work if they weren't introducing plasma level heat into the process. With catalytic converter type heat being introduced the water would instantly vaporize right along with the fuel mixture BEFORE getting to the cylinder.
