HEmi 07
Old Jul 1, 2008 | 02:06 PM
kicker417's Avatar
kicker417
Default HEmi 07
ok i have a dodge qc sport 2007 with da HEMI when iam at a light somethimes my idle drops to 500-400 rpm and it gives a little vibration while the rpm is there is that bad or do all hemis do that.
Old Jul 1, 2008 | 02:17 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Default RE: HEmi 07
mine doesn't. you make any modifications recently? programmer, maybe switched the type of fuel you were using? I'd give it a few days if you modded anything. bet it picks back up.
Old Jul 1, 2008 | 02:49 PM
kicker417's Avatar
kicker417
Default RE: HEmi 07
no its been doin it since day1 it did it b4 any modifications it only does when i at a light in other words when iam holding the brake
Old Jul 1, 2008 | 04:32 PM
trx450's Avatar
trx450
Default RE: HEmi 07
mine does that too i wouldent really worry about it
Old Jul 1, 2008 | 06:47 PM
HemiJay's Avatar
HemiJay
Default RE: HEmi 07
Yeah, mine does the same thing at idle after a few seconds. It scares the crap out of me when my gas light is on though..
Old Jul 1, 2008 | 08:45 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default RE: HEmi 07
Mine does it also....it vibrates because the idle is to low. If you buy a programmer you should be able to raise the stock idle a few hundred rpm's depending on which handheld you buy/have.
Old Jul 1, 2008 | 10:18 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: HEmi 07
They all do it... if it bothers you that much keep the brake pedal down and lightly tap the gas pedal and the RPMs will go back to normal.... Kinda seems that when the transmission downshifts it bring the RPMs down and forgets to let it go...
Old Jul 2, 2008 | 01:03 AM
kicker417's Avatar
kicker417
Default RE: HEmi 07
no it dont bother me just wanted to make sure it was nuthin bad
Old Jul 2, 2008 | 01:11 AM
xfeejayx's Avatar
xfeejayx
Default RE: HEmi 07
that's weird. my 04 never does that. but it's obviously common on the 07. well, at least you know not to worry
Old Jul 2, 2008 | 01:25 AM
MinatorHemi8's Avatar
MinatorHemi8
Default RE: HEmi 07
my '06 doesnt do it, and it was the first model with the gas saving module the lowest mine drops to is 1,500 when operating on 4 cylinders.
Maybe its a new mod to the system.
