E-fan size
Everything ive read on the site about it says this fan is king ****:
http://moesperformance.com/index.php...products_id=15
ORIGINAL: semigod
that flexalite is the whole kkit.
daytona1680, did you have to do much trimming/custom fab to get the mark viii fan to fit?
Trending Topics
I wouldn't do it if you tow a lot...you'd be hard pressed to find an electric fan that pulls the same cfm as a clutch fan at full lock up. The electric fan does reign supreme at idle though...it's a give and take kinda deal.
ORIGINAL: xfeejayx
http://moesperformance.com/images/fa...%20delete1.JPG
so the markviii fits pretty easy inside the stock shroud huh? also, what are you using as far as a controller?
severedistortion, an e-fan is a definate must if you are towing. if you ever get stuck in traffic, you want that e-fan to cool off the engine that was just working hard for however many miles. also, when going highway speeds, the air from you driving will beat most any fan out there anyway.
