changing plugs...
Old Jul 11, 2008 | 07:53 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: changing plugs...
Cyclone,
Check this linkhttp://www.sparkplugs.com/results_ap...p;AAIA=1430808
Go all the way to the bottom for the OEM plug.
Old Jul 11, 2008 | 10:32 PM
brad m's Avatar
brad m
just changed mine tonight and they where pretty easy just over 1 hour. To ge the electrical connector off push it on more and then push out the saftey tab. Good luck.
Old Jul 12, 2008 | 01:03 AM
eastxHEMIram's Avatar
eastxHEMIram
Yeah, first time I changed mine, I "lost" a coil pack bolt in the folds of the intake manifold. Took forever to hunt it down. Last couple times, I remembered to remove the bolts just in case. Don't know if it'll help, but I found that for the rear plugs, I had to drop the various tools (plug socket, short extension, universal joint, then ratchet) one at a time to fit under the booster. Couldn't fit it onto the plug while all attached to eachother. Also...a thick blanket draped over the crossmember & onto the bumper will help deter knee and rib bruising!
