changing plugs...
Old Jul 8, 2008 | 12:01 AM
cyclone429's Avatar
cyclone429
Default changing plugs...
I got a quote for 350.00 cdn to change the plugs in my 5.7. five bucks per plug times 16 + Labour.
Never new copper went up in price, how ever, I decdied I'm doing it my self.
The 2 plugs behind the brake boaster look like a SOB, + the coil pack. but I'm going to do it.
I'm new to coil packs, I have swapped out a lot of plugs with spark plug wires, but I do have questions with the coil packs.
Disconecting the battery is a no brainer, but do I have to disconect the connection to the coil pack, or can I just take off the coil pack to get at the Plugs?
Once I take off the coil pack, is thier a gasket or rubber seal that seals on to the valve cover?
A lot of advise says to use copper plugs, but why every 50,000 km? On my old beaters from the 80's I could get four times the life out of the same copper plug, but Iron block, iron heads, dose a AL. head do something to the Copper?
And how tight are the plugs installed at the factery, I don't want to bust off the ceramic part of the plug, bean thier done that, but than I was never worried, back than I had my own version of MDS....
Now, is going to A Iradium plug going to foul up the plugs? I have been told the igntion coumputer ( ya I know its one for all the truck ) gets confused trying to fire a Platt. plug amd works best with copper..
Thanks .....
Old Jul 8, 2008 | 01:19 AM
TheUsed801's Avatar
TheUsed801
Default RE: changing plugs...
What engine do you have?
Old Jul 8, 2008 | 01:44 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
You'll hear all kinds of BS...when it comes down to it a plug is a plug as long as they're in the same heat range. Gap them correctly and they'll fire just fine....and don't over tighten. Some last longer than others...and that's what you pay for with the Iridium plugs or plats.
Do the plugs yourself...even if it takes you 6 hours for whatever reason think of it as you paying yourself $50 an hour.
Old Jul 8, 2008 | 09:12 AM
Gone Fishin's Avatar
Gone Fishin
Get yourself a swivel head plug socket and 3-4" extension in 3/8". Piece of cake. I believe the coil packs take a 10mm. The reason for the change on the the coppers is they do wear down fairly fast and seriously open the gap. I change mine out every 30k miles and notice a perceptable difference in how it runs every time.
Which reminds me, I'll be at 90K in a couple of months, better get'em ordered soon.
Old Jul 8, 2008 | 09:19 AM
HammerZ71's Avatar
HammerZ71
It's a PIA compared to most vehicles, but still something you can do yourself and save a ton of $.
There's a DIY on it I did the other day for someone here...
https://dodgeforum.com/m_1356315/mpa...tm.htm#1356315
Old Jul 8, 2008 | 12:49 PM
chefred112's Avatar
chefred112
you don't have to remove anything from the coil packs (unless you want to)...I don't even pull the battery cable off either (I've changed my plugs so much)...unscrew the 2 bolts holding them down and pull it outta the way other then that, it just takes time (about an hour an a half for me) to do em...when I go to the track, sometimes I just replace the coil pack plug (primary)
Old Jul 8, 2008 | 01:03 PM
kenihemi's Avatar
kenihemi
Chefred said it great.
Only thing I'll add is be carefull of the coil bolts. I had one drop into one of the plug holes.
Old Jul 8, 2008 | 01:07 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: kenihemi
Yikes!! Good thing you knoew where it went, if that would have got into the cylinder bad things would have happened.
I sat on the cross member where the hood latches doing most of mine, made it easy.
Old Jul 8, 2008 | 07:16 PM
kenihemi's Avatar
kenihemi
I couldn't find it anywhere, took one of the telescoping magnets and fished around in the plug holes and "clink". Thank God.
Best to remove them and put them aside while the coils are out.
Old Jul 11, 2008 | 07:42 PM
cyclone429's Avatar
cyclone429
Parts source sells a pack of 2 champion spark plugs for 5 bucks, cdn dealer mark up was 5 bucks for one plug.... Bought them. all 16, but As I pulled out the first plug, it still looks new, not brand new, but still in good shape..
Just for a note, bosch platium 4+ were 19.00 for two plugs....
