sound system time
Old Jul 14, 2008 | 10:55 AM
  #21
05redhemi's Avatar
05redhemi
Default RE: sound system time
oh dam that completely changes what i had in mind honestly i thought it was an exact #'s matching game wow much appreciated for savin me money in the long run now time to start searching for deals
any more input is also much appreciated
Old Jul 14, 2008 | 11:17 AM
  #22
05redhemi's Avatar
05redhemi
Quantity
Description
InStock?
RegPrice
Your Price
Remove
SavetoWishlist
Rockford Fosgate Power T400-460W x 4 Car Amplifier
Yes
$399.99
» Add ServiceNet Replacement Plan
» Add Accessories
Remove
SavetoWishlist
Alpine IDA-X200Receiver with iPod Protocol
[*]Price Break - Save $25: Was $224.99[/ul]
Vehicle: 2005 Dodge Ram 1500 Pickup Quad Cab with 4 speakers (change)
Yes
$199.99
» Add Accessories
1
Receiver Kit 120996503
Yes
$14.99
FREE
1
Receiver Harness 120706502
Yes
$14.99
FREE
1
Receiver Antenna Adapter 12040CR10
Yes
$12.99
FREE
Remove
SavetoWishlist
Q-Logic QLH-1.2510DSDual 10" Hatch/Trunk Box-Vol=1.25 cubic
Yes
$169.99
» Add Accessories
Remove
SavetoWishlist
StreetWires PSK04Ri 4 gaugeAmp Wiring Kit Red with Patch Cable
[*]Get 50% off with a select amp [/ul]
Yes
$109.99
$54.99
» Add Accessories
Remove
SavetoWishlist
MTX XThunder XT10-0410" 4-ohm Component Subwoofer
Yes
$179.98
» Add Accessories
Remove
SavetoWishlist
RF RFFM100 100amp MAXIPlatinum Plated Wafer Fuse
Yes
$3.99
Remove
SavetoWishlist
StreetWires UCT12 per foot12 gauge Blue/Copper Speaker Wire
Yes
$0.80
» Add Accessories
1
Crutchfield MasterSheet Instructions
Yes
$4.99
FREE
1
FREE Crutchfield Guide: Amplifier Installation
Yes
FREE
1
FREE Crutchfield Guide: Subwoofer Installation
Yes
FREE
Merchandise Subtotal:
$1,009.73
Old Jul 14, 2008 | 11:19 AM
  #23
05redhemi's Avatar
05redhemi
heres wat i came up with
srry had no other way than to copy paste[&:]
Old Jul 14, 2008 | 12:08 PM
  #24
hometheaterman's Avatar
hometheaterman
Looks like an okay system to me although I haven't researched any of the things. A few questions though it looks like you are only getting one 10" MTX sub. Is that correct? If so why are you getting a Q Logic dual 10" sub box that's for two of the subs?
The other question is I don't see any speakers in there so I'm assuming the amp is to power the subs. Why are you getting a 4 channel amp to power the subs? I'd look for a nice single channel amp for the subs or at max a 2 channel. I'd get a nice amp for the subs then if you want to power the speakers with an amp get a distribution block and run a second amp for them.
Old Jul 14, 2008 | 07:25 PM
  #25
lxman1's Avatar
lxman1
Site Moderator
Yep, I just installed a cheap set of Sony Explode's in my doors for now. The are 93 d per watt and are much louder and clearer than the stockers. I will later upgrade to Alpine R's when the money is available. 6x9 in the front and 6.5" in the rear.
The stock dual cone rear door speakers are much better than the factory front door speakers. They are nice and heavy with a large magnet. The front ones are not.
Old Jul 17, 2008 | 10:44 AM
  #26
05redhemi's Avatar
05redhemi
ha guys just took a trip to the local audio system and weh priced out something that ill be happy with
2 mtx4500 with the thunderformbox (subs have built in amps)
http://www.mtx.com/caraudio/products...hunderform.cfm(search for an dodge ram quadcab 2005)
clarion head unit
http://www.clarion.com/ca/en/product...393339632.html
will later in the future replace the door speakers
the subs each have there own amp built in and the head unit has a 53W x 4 Built-in MOS-FET Amplifier built in so it will make the door speakers pump it out. i was talking to the audio guy there and he said the stock speaks will sound 10 times better and be able to take it
everything together wiring labour taxes and all it comes out to 1588.99 out the door. ill probably be able to talk him to 1500.00 even.
wadda ya think
Old Jul 25, 2008 | 04:41 AM
  #27
devildg84's Avatar
devildg84
not bad i spent $180 on a box for 2 tens, and about $300 on the subs, $30 wiring, $100 capasitior, $200 for the amp back when i got it so i spent about $800 on all of it and installed it myself but ur also getting a head unit and i still have the stock one.i would say you might want to see if they will work with you on the price. but sounds good to me mtx is a good sub and amp.hope that helped alittle bit
Old Jan 26, 2010 | 07:19 PM
  #28
m.taylor4300's Avatar
m.taylor4300
What are the speaker size for the front and rear doors?
