2008 4 wheel drive ?
Old Jul 10, 2008 | 12:45 PM
ironbyron's Avatar
ironbyron
Default 2008 4 wheel drive ?
Is anybody else having problems trying to engage there truck into4 wheel drive with there 5 position electronic shifter.It just doesn't seem to want to go into low.Maybe I'm not doing something right? Regards,iron
2008 Hemi Ram Quad Cab Auto
Old Jul 10, 2008 | 01:50 PM
pilottim's Avatar
pilottim
Default RE: 2008 4 wheel drive ?
Have you put the transmission in neutral then selecting low?
Old Jul 10, 2008 | 06:16 PM
jtruck618's Avatar
jtruck618
What kind of mess were you in to need 4lo?
Old Jul 10, 2008 | 06:37 PM
ironbyron's Avatar
ironbyron
Thanks for the reply.Yes I did try the neutral.I thought I would try out 4 wheel low to see if it worked and its a good thingI did because none of it works.I brought it to the dealer this afternoon and andthey had that deer in the headlight look.So I guess its service time on a brand new vehicle.Regards, Iron
Old Jul 10, 2008 | 08:08 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Did you slow down to 2-3 MPH? If your rolling to fast it won't engage... and if you stop completly it somtimes won't go either..
Old Jul 10, 2008 | 08:33 PM
sos's Avatar
sos
Yeah 4 Lo is for very slow speeds, like below 10mph. Unless you are doing serious offroading you will probably never need it.
Old Jul 10, 2008 | 10:08 PM
HarvinJeep's Avatar
HarvinJeep
Stop, put it in neutral, then engage 4Lo, pause for a couple of secs in HI to let it switch over before you go to lo. If it does not work, roll te truck about a foot or so and repeat. Some times the gears are not lined up and it prevents it from switching over, rolling a very short distance with spin the gearbox a little bit to help line the gears up better.
Old Jul 11, 2008 | 08:16 AM
sschevy400's Avatar
sschevy400
ORIGINAL: 07 Ram TRX4
My 08 is the same way. Sometimes the gears are not lined up to mess correctly.
