60,000 mile maintenence
Old Jul 21, 2008 | 05:10 AM
Max00racer's Avatar
Max00racer
Default 60,000 mile maintenence
Aside from plugs and wires what else should I be looking out for?
Old Jul 21, 2008 | 07:11 AM
RamWood's Avatar
RamWood
Default RE: 60,000 mile maintenence
Manual.
Old Jul 21, 2008 | 08:12 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
diff fluids, throttle body, pcv valve?, transfer case fluid, grease joints, check belt, check hoses, coolant...that's the short list.
Old Jul 21, 2008 | 08:24 AM
talon6's Avatar
talon6
some people donnt have a manual. what about the trans.? whats the miles on it? i am just about there myself.(60k)
thanks,xfeejayx.
Old Jul 21, 2008 | 07:06 PM
5STARJOE's Avatar
5STARJOE
Air filter as needed
Throttle body 30k
Fuel Injection service 30k
Spark plugs Hemi 30k (16)
Transmission 30k
Differentials 12-15k intervals
T case 30k
Rotate 6k
fuel filter 30k (gas)
Old Jul 21, 2008 | 07:11 PM
sos's Avatar
sos
If you don't have a manual, you can download one from Dodge's site. http://www.dodge.com/en/owners/manuals/index.html
Old Jul 21, 2008 | 08:40 PM
HammerZ71's Avatar
HammerZ71
Yea, every 30k is a big one. So at 60k there's a lot that should be done.
Plugs, filters, differentials, transfer case (if 4x4), tranny, throttle body and basically everything needs to be checked...
Old Jul 21, 2008 | 11:30 PM
xfeejayx's Avatar
xfeejayx
fuel filter every 30k?! really? diff every 12-15?! wtf. something ain't right if your fuel filter is going out every 30k. and unless you do a bad job sealing the diff and go off roading, it shouldn't need to be changed every 12k, maybe checked.
fuel injection service...what does that even mean?
Old Jul 22, 2008 | 02:30 PM
HammerZ71's Avatar
HammerZ71
Yea, thats a little often on the fuel filter unless maybe you do the econo gas every fill up. As far as the diffs go, I do my rear diff every 15k, but that's because I have the Auburn Gear LSD that requires conventional lube. I have synthetic in the front and plan on letting that go for 45k miles.
As far as a fuel injector "service" I've always used a high end cleaner in my gas tank every 3000 miles and have never had an issue...
