sts turbo for hemi ram
Old Aug 3, 2008 | 01:40 AM
bluealphadragon's Avatar
bluealphadragon
Junior Member
Default sts turbo for hemi ram
i have a couple of questions:
1. does the sts kit come with a BOV
2. what do i need to run 7 psi (i know i need meth kit and plan on getting one) besides the sts kit or is it set up for 7 psi already.
thanks for any help you can give me
Old Aug 3, 2008 | 03:16 PM
FrostKing's Avatar
FrostKing
Default RE: sts turbo for hemi ram
The kit comes with both the BOV and wastegate. You will also need 8 larger fuel injectors and some form of tuning, whether it be SCT or a SMT-6 piggyback. The wastegate comes with a 5 psi spring so that will be the boost limit unless you also get an optional boost controller to raise the pressure.
Old Aug 5, 2008 | 09:42 AM
bluealphadragon
Junior Member
thanks, im in contact with krc performance they said i need 60# injectors and a 2 bar map sensor and they have a kit that comes with everything just its 6500 and the kit from sts ive found one for 3800 new the thing is i really dont know if i can tune it myself i know a good bit about engines and stuff but other than the superchips plug and play that is my extent of tuning.
Old Aug 5, 2008 | 01:18 PM
kenihemi's Avatar
kenihemi
The sts kit does not include a BOV. A BOV is extra.
It is set up for 5lbs boost. To make 7lbs you have to get a boost controller.
You don't need meth injection if you get an intercooler.
Old Aug 5, 2008 | 02:54 PM
bluealphadragon
Junior Member
ok i just dont know about tuning could i get the smt6 and do it myself?
and i dont want to mess my truck up.
if i do go with the kit from krc i would like to know what i'm getting what all comes with the kit?
all over your help is to make the best choice i can, and i know that krc will give me tech support and that is a big plus
Old Aug 5, 2008 | 06:32 PM
kenihemi's Avatar
kenihemi
My 04 did not like the smt-6. I now have the sct tuner, not the pre-progammed progammer.
You will also need larger injectors and a 2BAR MAP sensor.
Old Aug 5, 2008 | 08:45 PM
bluealphadragon
Junior Member
what size injectors and if i bought the kit and peices where i could find the best deal would krc still sell me the tuner with the program i need?
Old Aug 5, 2008 | 08:49 PM
kenihemi's Avatar
kenihemi
I have the Ford SVT Cobra "blue injectors.
I have no idea what KRC does.
Old Aug 5, 2008 | 10:13 PM
bluealphadragon
Junior Member
thanks what size pipe is the kit for intercooler perpose cause i might intercool it instead of meth kit
Old Aug 5, 2008 | 10:19 PM
bluealphadragon
Junior Member
by the way where did you get your sct program at and the tuner
