Change Oil Warning ?
Old Aug 4, 2008 | 02:03 PM
RamMan25's Avatar
RamMan25
Default Change Oil Warning ?
I changed my oil for the first time on my truck, the Change oil warning cam on around 5200 miles, I changed the oil and I figured the warning would go away, it has not. How do I make it go away?
Old Aug 4, 2008 | 02:19 PM
jstmahoney's Avatar
jstmahoney
Default RE: Change Oil Warning ?
I think you have to turn the key to "on" without starting the engene.
Old Aug 4, 2008 | 02:20 PM
jstmahoney's Avatar
jstmahoney
and floor it 3 times, turn the key to off, and then start her up,
Old Aug 4, 2008 | 02:22 PM
jstmahoney's Avatar
jstmahoney
see if it goes away
Old Aug 4, 2008 | 02:23 PM
jstmahoney's Avatar
jstmahoney
somthing like that
Old Aug 4, 2008 | 02:24 PM
jstmahoney's Avatar
jstmahoney
someone that knows for sure will chime in...
Old Aug 4, 2008 | 09:45 PM
PhotoRam's Avatar
PhotoRam
Yep, get in close door, turn key to run without starting. Depress gas pedal to the floor three times. turn key off. You're done.
Old Aug 4, 2008 | 11:40 PM
mmstar23's Avatar
mmstar23
would it be the same for a jeep grand cherokee laredo? my mom has an 07 and it says service engine. i changed the oil and checked everything, and it still says it on the dash
