How to remove the glove box on 05 ram?
Old Aug 5, 2008 | 01:12 PM
nemesisprogram's Avatar
nemesisprogram
Default How to remove the glove box on 05 ram?
Anyone know? I am trying to find my siriuse radio reciever... im gunna look in the spot first
Thanks
Old Aug 5, 2008 | 05:34 PM
sos's Avatar
sos
I'm not sure if the '05 is the same as my '08, but considering my '00 Dakota was very similar, I am guessing it is... Open the glove box, let it drop fully open, then squeeze the two sides in the back together until the rubber bumpers clear the sides of the dash where they hit. Once you do that, pull the glove box open further and it will come right down. I did mine the other day, and from the looks of it, the Sirius is still hard to reach even with the glove box removed.
Old Aug 5, 2008 | 06:55 PM
Mancunian's Avatar
Mancunian
On my 2003 the Sirius box is behind and above the glovebox opening. To remove the glovebox, I had to locate the two plastic tongues at the back of the open lid and force them down to clear the stops. The door will then swing all of the way down and come out of the half hinges altogether
Steve
Old Aug 9, 2008 | 06:58 PM
nemesisprogram
I got the glove box open but theres like a plastic wall right when you take it off. I did not see anything. Its only a single cab where else would it be>??
Old Aug 9, 2008 | 08:39 PM
Mancunian's Avatar
Mancunian
You need to look up behind where the glove box is. On mine, the Sirius component is screwed onto a steel frame tube and I believe it is a bugger to get at. I left mine where it was and instaled a Pioneer 6000 head unit ad Pioneer XM tuner which went under and behind the back seat on my quad cab. Man I love this Pioneer unit !!!
Steve
Old Aug 9, 2008 | 09:18 PM
Parts/Service's Avatar
Parts/Service
this is out of the service manual...
REGULAR CAB
Disconnect and isolate the battery negative cable.
Place front passenger seat in the forward position.
Remove the mounting fasteners.
Disconnect the antenna cable and electrical harness connectors.
Remove the satellite receiver.
See attached pic.....
Old Aug 9, 2008 | 10:37 PM
nemesisprogram
Omg its under my seat ...LMAO Thank you !
Old Aug 10, 2008 | 01:51 AM
Ben D.'s Avatar
Ben D.
for my 08 sat radio reciever the sirius box is behind my glovebox had it out in the shop today to make sure the antenna would work with my sirius direct box for the new pioneer navigation in dash i'm going to be getting. and it does so w00t
Old Aug 10, 2008 | 04:13 PM
nemesisprogram
Hey Parts/service I checked today and the reciver is not in that location. I give up
Old Aug 10, 2008 | 07:48 PM
nemesisprogram
Default Best rubbing compound?
Damnnn
