HELP Alarm System Going Haywire
the reason the truck won't start is due to the ignition cut out that is built into the alarm. when the battery is disconnected it assumes a break in and this alarm and disrupts the ignition. the reset button will fix both problems but your alarm will not work the same until you get it reprogrammed. when I sat it won't work right it just means that the alarm will not sound and the ignition will not be disrupted. If you were to get a keyfob remote then they may be able to reprogram it at the dealership.
