Problem w/power locks
Old Aug 9, 2008 | 08:32 PM
The Dude's Avatar
The Dude
Junior Member
Default Problem w/power locks
Have a 2002 ram 1500 and my power locks are working on three of the doors, however, on the back drive side door it doesn't respond. Same thing happens when I use my keyless remote or the switch inside the cab. If someone could enlighten me with a solution that would be great!!!!
Old Aug 9, 2008 | 09:20 PM
Parts/Service's Avatar
Parts/Service
Sounds like you need to check out the door latch in the door. The solenoid that unlocks the door is in the latch..
Old Aug 10, 2008 | 01:18 PM
The Dude's Avatar
The Dude
Junior Member
Will do. Thanks
Old Aug 10, 2008 | 02:03 PM
John  M's Avatar
John M
From what I've read, these trucks typically have problems with wires breaking inside the door jamb. I guess it's all the flexing. Dodges seem to suffer from that moreso than the other vehicles I've owned that were 10+ years old.
Old May 6, 2009 | 09:24 PM
my02ram's Avatar
my02ram
I also have a 02 ram with right rear door lock issues. I have removed the door panel and checked the wiring. I was confused till i discovered that the door locks have 12 + and the 12- is used to lock and unlock the door.
It appears that I need a new actuator for the lock. Where can I find a good price for the actuator?
Old May 6, 2009 | 10:05 PM
hemiguy0302's Avatar
hemiguy0302
Im sure its the wiring harness that goes between the door and the body.
This was the problem on mine and on my buddies so give this a try. 15
minutes with some solder and shrinkwrap it will be good. I solved the problem
by replacing all the wires on that harness
Old May 6, 2009 | 11:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My drivers door used to do the same thing. I had to replace the lock/latch assembly and I have no more issues. I checked with a meter for power and I know I had a bad unit.
Old Jul 16, 2009 | 11:15 PM
Demolddudesgoeverywhere's Avatar
I tried a new actuator and still nothing. I got the same thing going on. It seems that the voltage is there. I guess I'll check between the jamb. I'm not sure what I should see with my meter on the wires.
Old Jul 16, 2009 | 11:53 PM
eaglestorm's Avatar
eaglestorm
you dont need a meter pull the rubber boot back for the door wiring and thats where you will find the broken wire or wires
