Engine ticks when first started
Old Aug 10, 2008 | 01:45 AM
AquaticZERO's Avatar
AquaticZERO
Junior Member
Default Engine ticks when first started
Engine ticks when first started then seems to go away after about 10 mins.There is lots of oil in it any ideas?
Old Aug 10, 2008 | 03:35 AM
chefred112's Avatar
chefred112
Hemi drivetrains are inherently noisey...I have 130k miles on my 05 and it still ticks to this day...we use to make a big issue out of this but now we just ignore it and move on and mod away...
Old Aug 10, 2008 | 07:02 AM
seawind3000's Avatar
seawind3000
Try a 1/2 can of seafoam in your crankcase. You don't need to drain it out after and you can drive the truck normally with the seafoam in there. One oil journal might be partly plugged, the seafoam will clean it out. Use the other half in the gas tank to clean the fuel system, best to use the 1/2 can with just under 1/2 a tankful of gas. Let us know the outcome.
Mike
Old Aug 10, 2008 | 08:54 AM
Der Schatten's Avatar
Der Schatten
mine does the same thing, but only after switching to Royal Purple. i've got the 4.7 also, not the Hemi. i cleaned out the engine before with 16oz seafoam before i did the change, let it run for 20 minutes to get warm and circulated. now it ticks like hell. i run 3 oz seafoam in the engine right now. but i'm still 5,000 miles away from an oil change.
Old Aug 10, 2008 | 12:41 PM
Heminator2's Avatar
Heminator2
I have very little Hemi tick in our 05, because I use Amsoil SSO 10W/30 oil in it. Synthetic oil, I assume, helps with the problem.
Old Aug 10, 2008 | 04:38 PM
TheTransporter's Avatar
TheTransporter
New Member
I have a 4.7 and mine has always ticked too. Runs just fine so I really wouldn't sweat it too much if you can't fix it.
Old Aug 10, 2008 | 09:24 PM
AquaticZERO
Junior Member
Sorry let me give a few more details.It is the 4.7 and never had this noise before until yesturday.It ticks as soon as you start and increases with acceleration but seems to go away after about 10 mins or so, doesn't seem to effect performance.Could it need a tune up maybe new spark plugs?
Old Aug 10, 2008 | 09:43 PM
devildg84's Avatar
devildg84
mine was ticking when i used regular gas, and regular oil and i switched to med grade gas/ premium and royal purple and its not as loud and runs much better i have a 06 hemi
Old Aug 11, 2008 | 06:41 AM
seawind3000
If it ticks on start-up and goes away in 10 min. then it's "cold oil". When the oil warms up the tick stops. Clean the sludge and put in a good syn oil. The seafoam & syn oil should fix the tick. My .02
Mike
Old Aug 12, 2008 | 08:42 PM
revtodd's Avatar
revtodd
i have a 2003 4.7 and mine ticked on start up till last week oil pressure dropped and found out that this is an occurance on the 4.7 . my suggestion is to run a cleaner through it to get the sludge out of it or you will have to drop the oil pan and clean up the oil tube
