any suggestions 2003 1500 4.7
Old Aug 12, 2008 | 12:43 PM
revtodd's Avatar
revtodd
Default any suggestions 2003 1500 4.7
got a 2003 dodge ram 1500 and oil pressure dropped so i put a new oil pump in and it is doing better but it still drops to low and i have to rev the engine to get it back up also the rpms have dropped to to 6,000 rpms at idle. i have ordered a crank shaft pos sensor and a oil pressure guage but was wondering if anyone else has had this prob?
Old Aug 12, 2008 | 12:59 PM
AIR RAM's Avatar
AIR RAM
I would check the (Oil Sending Unit & Gauge) before I changed ANYTHING. That must have been allot of work swapping out the pump... did you do it yourself? I cant see the crank position sensor having anything to do with it.
SPEED SAFE, AIR RAM
Old Aug 12, 2008 | 01:02 PM
mmstar23's Avatar
mmstar23
https://dodgeforum.com/forum/3rd-gen-ram-tech/167261-help-oil-pressure-fixed.html
Old Aug 12, 2008 | 02:48 PM
HammerZ71's Avatar
HammerZ71
Was waiting for you to jump all over this one...
Old Aug 15, 2008 | 07:46 PM
popps68's Avatar
popps68
You didn't say what year? how many miles?? I have ran across a few fords that the oil pump got a little weak before finally quitting on me. We had an old ram work van with the 360 it had 214,000 miles and the oil pump got weak, the guy who bought it had a new pump put on it and the thing is still running as good as ever.
Old Aug 15, 2008 | 07:47 PM
popps68's Avatar
popps68
Sorry dude, you did tell the year!
but not the miles?
Old Aug 16, 2008 | 08:54 AM
revtodd's Avatar
revtodd
113,000 Dodge Ram 1500 4X4
Old Aug 16, 2008 | 01:45 PM
Pyro's Avatar
Pyro
I Beat Tetris
My truck idles at 500-525 rpm constantly, and its never stalled on me. My oil pressure is also lower at idle than operating speed. Never had any engine problems.
Old Aug 23, 2008 | 05:17 PM
popps68's Avatar
popps68
Hey revtod,
Mine is the same ,05 4.7 q.c.You know you might start thinking about main bearings, rod bearings,these things also can lower oil pressure over time especially if you got over 100,000 mile on her, also has she been serviced and at what intervals?? Do you drive mainly in the city or freeway?
Old Aug 24, 2008 | 08:07 AM
revtodd's Avatar
revtodd
problem solved. it was carbon build up . i guess i went further than i had to with repairs as i have found some on here with same problem. i have ended up replacing oil pump, and oil pick up tube and running 2 seperate clean outs through motor .oil pressure fine now and through it all i have a new mellng oil pump on it and should not have this problem anymore cause i plan to put the sea foam in it right before every oil change to keep the carbon out of it but if anyone needs to change their oil pump let me know i can save you trouble .
