electrical plug conecters
Old Aug 23, 2008 | 01:29 PM
carl550k's Avatar
carl550k
Default electrical plug conecters
hey all, was messing with the tailights on 04 ram qc 1500 the other day. whats the trick for sliding out the little red clips that hold the electrical plugs together? i almost destroyed mine before it finally came out. i also noticed that they are everywhere on this truck. the haynes manual i have says that they just slide out, this wasn't the case. thanks in advance, carl
Old Aug 23, 2008 | 06:01 PM
RaiderJay6's Avatar
RaiderJay6
They slide back and then you press the clip on the socket to undo. They should not come out.
Old Aug 24, 2008 | 12:07 PM
carl550k's Avatar
carl550k
thanks for the reply. it sounds simple enough, but i ended up pretty much destroying the one with needle-nose pliers. it wouldn't budge. carl
