where is this o2 sensor?
Old Aug 26, 2008 | 04:27 AM
hearmehemi's Avatar
hearmehemi
New Member
Default where is this o2 sensor?
i have troubleshot an issue with my 03 ram 1500 5.7 hemi to this code "P0132....O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)". my problem is that i can't find anything taking me to bank1, sensor1. is tis something that i can repair on my own, or does it absolutley have to be done at a shop? I NEED HELP!!! this problem is driving my crazy. olus, if i can fix mine, i'm sure i can help one of my buddies that is having the similar issues. anybody out their, any information would be greatly appreciated.
Old Aug 26, 2008 | 05:29 AM
HammerZ71's Avatar
HammerZ71
1st sensor going back from the manifold on the drivers side. High voltage is an indicator that there is a lack of oxygen, but it's probably just a bad sensor, given the age of the truck. Replace it and see if the CEL goes away...
Old Aug 26, 2008 | 10:39 AM
hearmehemi's Avatar
hearmehemi
New Member
thanks, i'll give it a shot.
Old Aug 26, 2008 | 12:34 PM
lxman1's Avatar
lxman1
Site Moderator
Yep Bank 1 always means which ever side cyl number one is.
Sensor 1 is always between the motor and cat converter.
Old Aug 26, 2008 | 06:59 PM
FrostKing's Avatar
FrostKing
'03 trucks only have 2 sensors. You are looking for the pre-cat sensor at the 'Y' pipe. Change it yourself, it is cheap and easy to do. Make sure to use a little anti-sieze on the new sensor.
Old Aug 29, 2008 | 11:25 AM
hearmehemi's Avatar
hearmehemi
New Member
Default still O2 sensor issue
i thought that it was only 2 O2 sensors on this model. the pre- cat and aft- cat. i ad already changed the pre-cat, and the code was a P0420. after it was changed, that's when i got P0132. although it doesn't indicate it, should the aft-cat O2 sensor be changed as well? i tried pulling the battery cable to reset the computer so that when i turn the truck on it could re-cal for the new O2 sensor. anymore help and/or advice would be great.
Old Aug 29, 2008 | 02:11 PM
kenihemi's Avatar
kenihemi
P0420 is a cat efficiency problem.
P0132 is the front sensor.
Don't buy elcheapo sensors (not saying you did). Buy Dodge.
I would change the rear sensor and try it. The cat itself is really expensive.
