new plugs in hemi and gas milage is worse..
Old Aug 27, 2008 | 01:14 AM
cyclone429's Avatar
cyclone429
Default new plugs in hemi and gas milage is worse..
Hi, I changed the plugs in my 06 2500 5,7 Ram with Champions, Gap is correct, engine purs good, But I'm not getting the milage I used to with the old plugs, the old plugs were not not that bad, but close enough to warrent changing.
The power, performance is as per new, but I'm not running my truck any harder, I used to get up to 20 to 22 mpg hihway with the old plugs, the tbi is clean, air filter good, tire psi the same.
I now have 56,000 km on the truck, 80 % of the milage to date is all highway, I'm getting betwean 16 to 18 mpg at 60 mph in 6th gear, 2000 Rpm.
Thoughts? I'm tempted to reset the coumputer....
only mods are dual ex, cab hig topper, all with the old plugs....
Old Aug 27, 2008 | 07:56 AM
dazed01's Avatar
dazed01
Are the new plugs the same part number?
Old Aug 27, 2008 | 05:05 PM
Gone Fishin's Avatar
Gone Fishin
Reset the computer---let it relearn the engine and your driving habits
Did you get the plugs tightened enough to get good compression? I know, it sounds like a stupid question----but if you didn't, that might be an answer. It is also possible you may have over-tightened them---pushing the seal gasket out. I have noticed on some of the boxes the plugs come in, that they'll spec out something like 1/2 turn after contact---or something like that. Just some possible ideas
Old Aug 27, 2008 | 05:28 PM
ivaskaj's Avatar
ivaskaj
Put in Mopar plugs and regain your stock performance.
Old Aug 27, 2008 | 06:21 PM
MikeHTally's Avatar
MikeHTally
Put in good plugs (anything but Champions). Man, how can you drive slow enough to get 20-22? I'd fall asleep at that speed. :-)
Old Aug 27, 2008 | 07:56 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Did you remove anything when you did the plugs...like the intake silencer? If you did make sure you plug the IAT back in..
Old Aug 27, 2008 | 09:17 PM
dazed01's Avatar
dazed01
How do you like the speed 3 man? They are nice little cars and I haven't seen many problems with them yet.
Old Aug 27, 2008 | 11:00 PM
cyclone429's Avatar
cyclone429
I'm going to reset the coumputer, The identical champions, oem plugs, same part number are in the truck, coils are tight, plugs are tight, I really took my time changing the plugs, big pain the ****, I only have a 600 km on the new plugs.
I was told that the platuim or irridum plugs run to hot in the hemi, and best to go with the champions.
With a 132 lt tank or 35 gallons, it gets expensive filling my truck up, I do try some hyper milage tricks, with some degree of sucess.
