Sirius Questions here!!
Ok my 06 Ram came stock with Sirius radio with the factory head unit, I have since replaced out my factory head unit with an after market head unit but my Sirius doesn't work. I miss being able to listen to the same radio station for more than 20 miles before I need to look for another one. Is there anyway I can hook my Stock Sirius receiver to my after market head unit, I have a JVC KD-AVX2 CD/DVD player in my truck and it is able to control Sirius so that is not an issue. Is there some small connector I can use that will plug into my after market head unit and make all this work again. I would hate to get a new Sirius receiver unit even though there is nothing wrong with the one I currently have and also have to rerun the antenna and take the old one out so everything looks clean. Any idea at all guys would help me out.
If your new deck is Sat ready, there should be a connector/adapter slot on the back of the deck that the antenna would plug into. I had the same problem when I got a new deck. I took it back to the shop that I got the deck from and had them redo it. If you've done the install yourself, you could still take it to any decent shop and they should be able to give you some pointers or help out.
Ok Ben is it easy to get to the factory sirius tuner? Do I have to take the entire unit out and put in the new JVC stuff then just replace the wires? For the most part I am pretty good at doing this kind of stuff myself I just don't want to run into anything strange and really fudge up my radio.
Trending Topics
yea pop out the glove box and look up... you'll see a little box with some wires plugged into it. pop out the antenna and plug it into the stuff from jvc... the jvc box could be placed in the place of the factory stuff which is what i plan to do when I get a new h/u but it could stay there if ya don't want to remove it. the jvc box will probably need to be wired into power and ground and then antenna plugged in and it will come with a cable to connect to the back of the JVC and tada.
