EGR Valve I uhh think! 04 hemi
Old Aug 30, 2008 | 09:02 AM
Skywalker's Avatar
Skywalker
Default EGR Valve I uhh think! 04 hemi
I think I go the egr off. Is there any way to take it apart or how do you clean it? Do I even have the right part? It came off the PS head and has a tube that runes up to the back part of the throttle boddy, near the pcv valve.
Old Aug 30, 2008 | 11:40 AM
hemi head's Avatar
hemi head
It sounds like you got the right part.As far as cleaning it,i can't help you.
New one from Advance Auto is like $58 online only,not available in store and $75 at the dealer.
Old Aug 30, 2008 | 11:54 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Is your truck throwing a code or running bad? If not i'd just leave it be until you can replace it.
Old Aug 30, 2008 | 12:29 PM
HammerZ71's Avatar
HammerZ71
I don't know how many miles you got, but at the 60k mark, I'd replace the EGR anyway, it seems to go somewhere between 50 and 60k anyway for most. It will make your performance worse way before being bad enough to generate a CEL.
90% of the time, sluggish performance can be traced to either a dirty throttle body or bad EGR or both...
They were a hard to get item about a year ago, only available from the dealer and on like a 5 week back order so I ordered one and got it about a month later. It's sitting in my garage waiting. I've only just hit 40k so maybe I'll be lucky and it will sit a while longer...
Old Aug 30, 2008 | 07:29 PM
MrJallen84's Avatar
MrJallen84
New Member
I've got an '04 1500 QC w/ Hemi. Got it w/ 35k on it and now has 44k on it. Check engine light came on about 4k ago and it read EGR..i've been driving it since..sometimes it even turns off..I'm pretty sure it's screwed w/ my gas mileage slightly..but like these guys are saying you can drive it for a while. I bought the truck back home in Iowa and I'm stationed in North Carolina...seems like the humidity out here is what started it..b/c when I'm home it will go off, I've talked to some other dodge truck guys out here...and they are saying the same stuff..
Old Aug 31, 2008 | 08:16 AM
Skywalker's Avatar
Skywalker
Thanks guys! MY truck has a little over 67000 miles on it so I guess it was about that time. As far as fixing it I just went to the dealer and picked one up one for $66 that ain't to bad I don't guess! I'll be putting it back together this morning!
Old Aug 31, 2008 | 07:53 PM
lxman1's Avatar
lxman1
Site Moderator
How long is the emissions warranty on those trucks? That should be covered under the emissions warranty I believe.
Old Aug 31, 2008 | 09:05 PM
SeVeReDiStOrTiOn
Most newer vehicles cats are covered for 8/80k...the other stuff usually only goes until 50k.
Old Aug 31, 2008 | 09:23 PM
HammerZ71's Avatar
HammerZ71
If I'm not mistaken, Parts/Service checked for someone who's EGR went on them and he said that even though emission warranty was like 8/80, the EGR is consider a wear item and is only covered 3/36...
Old Sep 1, 2008 | 12:53 AM
lxman1's Avatar
lxman1
Site Moderator
Might be true, I never actually checked.
