no AC
Old Sep 4, 2008 | 05:47 PM
jonnymagnum's Avatar
jonnymagnum
Default no AC
I had my dash apart the other day trying to figure out how to take my ash tray out. then I figured the whole thing just pops out... so I hooked everything back up and now my AC wont work and it wont switch vents no matter what setting its on. the AC light lights up when you push it, but its still warm air comming out. it was all working fine before I took it apart and I took it back apart and made sure I connected everything and its fine. I could probly take it in for warranty, but I would rather try and fix this myself.
Old Sep 4, 2008 | 06:02 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a vacuum line off somewhere? If these use vacuum to actuate the doors.
Old Sep 4, 2008 | 07:04 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
When you pulled the dash off, did you by chance knock out or loosen the blend box and not get it back in properly? To check, just pull off your glove box door and reach your hand up and see if it is falling all over the place.
Old Sep 4, 2008 | 07:16 PM
jonnymagnum
all I had was the face off, just around the CD player and vents. it just popped out. maybe I messed up the vents some how, I'm gonna go out and see if the AC pump is actually engaging when I push the button.
Old Sep 4, 2008 | 10:45 PM
jonnymagnum
ok, I fixed it. I didnt plug one plug in all the way lol
Old Sep 5, 2008 | 01:41 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
To easy, I am going to leave it alone.....
Old Sep 5, 2008 | 01:54 AM
Pyro's Avatar
Pyro
I Beat Tetris
LOL! Simple mistake. I've seen worse. I had a friend in highschool who changed his brakepads himself, took off the old ones, got everything remounted, bled the brakes, took his car and realized he had no brakes...he forgot to put the new pads on
