CB Radio
Old Sep 4, 2008 | 10:40 PM
The Bull's Avatar
The Bull
Default CB Radio
Do any of yall run CB's?
Old Sep 4, 2008 | 11:35 PM
senselesscreationz's Avatar
senselesscreationz
i would also like to see some cb setups im prolly gonna put one in the truck soon
Old Sep 5, 2008 | 02:26 AM
ice.v8's Avatar
ice.v8
i have a cb on my 4.7 .... i put it under the steering wheel, and for the cb antenna i made an antenna mount and put it at the end of the bed
Old Sep 5, 2008 | 04:30 AM
greg14_00's Avatar
greg14_00
I have one in my work truck and i just mounted it in that little space under the heater controls in the middle of the dash. and for the antenna i mounted it on the inside of the box on the front corner. I also mounted a second antenna (not hooked up) on the other side of the box just for "looks" purpose.
Old Sep 5, 2008 | 06:09 AM
HammerZ71's Avatar
HammerZ71
They still make those things? Hell, I've not had a CB in a truck since I had an 8-Track tape player underneath it...
Old Sep 5, 2008 | 06:56 AM
greg14_00's Avatar
greg14_00
up here in northern ontario its almost manditory by my company to have one. dont want to meet up with a haul truck at 3 a.m. when your speeding down these bush roads trying to get to work.
Old Sep 5, 2008 | 04:52 PM
6 hemi ram's Avatar
6 hemi ram
here's where mine is:
however i did have to grind a rather large hole in the cross pipe behind the dash to accommodate the antennae connection.
Old Sep 15, 2008 | 11:17 AM
WhiteBerry's Avatar
WhiteBerry
i picked up the cobra 76 XTR (http://www.shopping.com/xPO-Cobra-76-XTR) which is one of their "all in your hand" models. it comes with a little box that has the power, mic, antenna, PA, and external speaker hookups, that is about 1-1/2"x1-1/2"x3-1/2" that i hid behind a kickplate by the cupholders. as for wires, i ran the power right to the battery through the firewall, the antenna is just the small magnet one that came with it, which i will be replacing with a dual 3' FireStik setup... the wire is temporarily ran through the rear sliding window, but when i perm mount it i will probably go through the firewall as well... unless i find a drain plug or something more convienent
