What is going on?
Old Sep 7, 2008 | 01:49 AM
Malu's Avatar
Malu
Default What is going on?
So I just got my baby back from the dealer. It was misfiring big time and turned out to be a collapsed valve spring. At first the dealer didn't want to fix it under warrenty saying the 7/70 only applied to the original owner. Luckily I had some connections and they ended up doing it for a $100 deductible. Now it's 3 days later and the engine light goes on again. I looked up the code here on the forum and found this - "P0456 Evap Leak Monitor Small (.020) Leak Detected". What does this mean and can I fix it myself? Is this causing the engine light to go on? The truck is also making a loud "tacking" sound after being shut down. It never did this before. It lasts about 4 minutes after shut down with about 5 seconds between tacks. I love my ram but am really frustrated right now please help.
Old Sep 7, 2008 | 02:07 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Hopefully they did the job right and replaced all the springs...do you know if they did?
As for the evap code...it could be a lot of things. Check the charcoal canister by the fuel tank and all tubes going into it...while you're down there check the fuel tank too.
Does the tacking sound exhaust related?
Old Sep 7, 2008 | 03:45 AM
radrickshemi's Avatar
radrickshemi
Check your gas cap.Same thing happened to my Scion,turned out to be a loose gas cap.
Old Sep 7, 2008 | 10:22 AM
dazed01's Avatar
dazed01
The evap leak is probably a cracked rubber evap line, check the rubber lines coming from the engine going to the charcoal canister and fuel tank. The ticking noise is probably just metal expanding and contracting when cooling down.
Old Sep 7, 2008 | 02:57 PM
POLICE RAM's Avatar
POLICE RAM
they should fix it, doesnt dodge have the transferrable warrenty?
Old Sep 7, 2008 | 05:26 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
yea the 7/70 is transferable. But you have to pay $100 or something when you get the truck to have it transfered to you within 30 days of buying it or somthing like that. If you didn't buy it, they are not liable. but if you bought it at a dealer (i didn't) maybe they do it automatically??
the lifetime warranty is not transferable
Old Sep 7, 2008 | 06:13 PM
Malu's Avatar
Malu
I just checked the paper work and it says that they only replaced the damaged spring. I hope this was an isolated incident. Sounds like the tacking sound could be from the exhaust but I just don't understand why it would start all of a sudden after getting it back, I never heard it before. What a coincidence. I'll check the hoses to see what kind of condition they're in. I put gas this morning and noticed that the gas gauge took a long time to go all the way to full. Usually it just shoots right up. Could this be because of the hoses and a vacum leak?
Old Sep 7, 2008 | 06:40 PM
POLICE RAM's Avatar
POLICE RAM
really,that sucks for someone privately buying a year old truck.
