4lo or 4hi for sand?
Old Sep 9, 2008 | 01:36 PM
RubberFrog's Avatar
RubberFrog
Default 4lo or 4hi for sand?
I was on the sand last weekend and I was wondering which is the best? I used 4 lo but it felt a little torquey.
Old Sep 9, 2008 | 02:28 PM
kenihemi's Avatar
kenihemi
Hi should be fine for most conditions. Use Lo when you bog down.
Old Sep 9, 2008 | 11:11 PM
WeightLifter500's Avatar
WeightLifter500
Just out of curiosity... if you get stuck ehile in 4 wheel hi how would you switch to 4 wheel low without grinding gears or anything. I have the manual shifter on the floor, which is much better than my last SUV that has it electronically. lol
Old Sep 9, 2008 | 11:23 PM
6 hemi ram's Avatar
6 hemi ram
airing down to about 15 psi will give you a b***er footprint with less chance of getting stuck as well as running in 4hi in sand.
Old Sep 10, 2008 | 02:26 AM
abarmby's Avatar
abarmby
Yeah that's the thing right there 6 hemi ram.
Airing down the tyres makes a great difference.
Just don't air them down too low, as they will pop off the rim.
Al.
Old Sep 10, 2008 | 06:38 AM
a4twenty's Avatar
a4twenty
4 lo is supposed have more torque and is actually more likely to spin the wheels. for sand use 4 hi and lower you tire pressure as mentioned above, save the 4 lo for when you need extra traction and more torque ( like pulling a buddy out of the mud hole )
Old Sep 10, 2008 | 09:01 AM
RubberFrog's Avatar
RubberFrog
Thanks for the replies. Although I've 4 wheeled a fair bit in my life, I've never really known what I was doing other than just trying not to get stuck. lol
Old Sep 10, 2008 | 10:02 AM
Pyro's Avatar
Pyro
I Beat Tetris
Check out the offroad section and this thread: https://dodgeforum.com/forum/off-topic/173712-off-road-guide.html
Old Sep 10, 2008 | 08:44 PM
cyclone429's Avatar
cyclone429
4 hi... 4 low will tear your truck apart and send your truck deap into earths bowels.
4 low is a torque gear, for towing out othier 4x4 owners who drive in 4 low, 4 hi is way more forgiving on the drive train.
One item to mention, you really only have 3 wheal drive, the front diff is open and if you don't have a LSD, you have two wheal drive...
I pulled out a 4x4 Ram that did not have a LSD. LSD are a extra cost option, only a small % of 4x4 rams don't have a LSD.
Old Sep 10, 2008 | 09:13 PM
M15's Avatar
M15
Air down and you'll be fine in 4hi. I've drove and ridden in alot of 2wd trucks in the sand dunes with no problems just by airing down.
