05 ram 1500 lam.
Old Sep 18, 2008 | 10:15 PM
tcooks's Avatar
tcooks
Unhappy 05 ram 1500 lam.
First dodge truck ever. need help. truck cuts out when throttle is stepped on. sometimes will not start at all. will be driving when engine will cut out then gain power back. engine light is on and sometimes flashing. checked gas cap but on securely. what do i need to use to check codes? is it the fuel filter, pump or spark problem, o2 censor? where do i start? any ideas?
Old Sep 18, 2008 | 10:39 PM
kx250frider617's Avatar
kx250frider617
take it to a mechanic so they can hook it up to the computer to find the codes or if you have a programmer, plug it in to that.
Old Sep 18, 2008 | 11:41 PM
Stunnerguy's Avatar
Stunnerguy
If there's a Autozone where you live, they can pull the codes for free...
Old Sep 19, 2008 | 12:58 PM
HammerZ71's Avatar
HammerZ71
Most auto part chain stores will read the codes for you. Once you know the codes, post them here and one of us can tell you what you need to do. Could be throttle body, EGR valve, TP Sensor or any of a host of things you can fix yourself with minimum skills and very little expense. But first thing is we gotta know those codes...
Old Sep 19, 2008 | 08:34 PM
tcooks's Avatar
tcooks
Hey, took my hemi to the dodge dealership and fault code po335 which is "Crankshaft Position sensor failure" came up. New part is on the way and is covered under warranty...thank god!
Next question: with this sensor not working, will this cause engine wear and why a sensor at this location? with older vehicals they do not have these so why now? is it to sence bearing wear? just wondering. Thx to all that reply to this message, Tim.
Old Sep 21, 2008 | 07:26 PM
onlyinadodge's Avatar
onlyinadodge
The computer system uses crankshaft and camshaft position to fire spark and injectors. They do not monitor wear. All cars with electronic ignition have had position sensors of some sort. Usually mounted in the distributor.
Once the dist. was done away with they needed new places to monitor rotation, hence mounted at the cam and crankshaft.
Old Sep 21, 2008 | 07:43 PM
CarGuyOhio's Avatar
CarGuyOhio
FYI on future codes, you can get them yourself. In the DIY section it explains how.
