ABS+Brake Light on
Old Sep 28, 2008 | 12:03 PM
Glee's Avatar
Glee
Default ABS+Brake Light on
I just bought an 03 1500 slt crewcab 5.7L.
the problem i have is.
when i start the truck up no lights are on.
when i start moving then hit the brakes i feel the abs pushing back on the brake pedal.
after a few times the abs + brake light come on and stay on and i no longer feel vibration in the pedal once the light comes on.
the symtoms are erratic one day i can go 10 ft and the lights come on the another time i can go 20 miles befor they come on.
oh one time the lights were on and i was stoped then i made a right hand turn and during the turn the lights went off for about 30 miles.
any advice would help thanks.
Old Sep 28, 2008 | 12:17 PM
sos's Avatar
sos
Sounds like the ABS system is not working properly. Since you had it go off when you turned a corner, it might be a faulty sensor or bad connection to the sensor at the wheel. It doesn't sound like it's a big deal, it's just telling you that the ABS system is not working.
Old Sep 28, 2008 | 03:22 PM
blyttle72's Avatar
blyttle72
Is your spedo acting up? Reason I ask is that is a common problem on the previous Generation of Ram. There is/was a speed sensor on the top of the rear diff.
When it failed it would light the abs and brake light.
Good luck.
Old Sep 28, 2008 | 03:47 PM
Glee's Avatar
Glee
thanks for the reply guys.
now you mention it i thought i did see the speedometer move from 20 to 60 once, when i was going down the highway
