Steering grind noise
Old Oct 4, 2008 | 10:57 PM
mackie's Avatar
mackie
Default Steering grind noise
Hey everyone, I am having a problem pinpointing AND even worse trying to show this problem to the shop that is covering the warranty. The problem is the truck will make the grinding hydralic like noise when I turn the steering wheel and pull out of a driveway or parking spot. It does it both warm and cold.
If its the steering pump, I would like it covered under the warranty before its up!
Oh yes, I have a 2004 Dodge RAM HEMI QuadCab 2wd with 110,000 KMS.
Thanks
Old Oct 6, 2008 | 01:03 PM
V_Scapes's Avatar
V_Scapes
It's either your pump or your hose has a hole in it and youve lost power steering fluid. its a common problem. it happened to me in the winter. get it checked soon.
Old Oct 7, 2008 | 03:27 PM
Cappy's Avatar
Cappy
My steering rack went bad on my 2006, with only 17k on it.
Old Oct 7, 2008 | 04:39 PM
ried69's Avatar
ried69
Is it like a grinding of metal on metal, or just a whining noise? My truck I noticed it starting to do that the other day. Just a little whining noise though.
Old Nov 5, 2008 | 08:17 PM
uspatriot's Avatar
uspatriot
steering column
