Old Aug 10, 2015, 05:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Changing Power Steering Fluid
Old Oct 10, 2008 | 03:30 PM
johnmichael's Avatar
johnmichael
I'm nervous about getting bubbles into the system when I'm changing it...I got my parts today, along with 3 qts of Valvoline ATF+4 Full synthetic.
So again, if someone could take a look at my process and let me know if it'll work or not, that'd be awesome...
I wanna just pop the top on the PS reservoir, pull the plugs at the base of the reservoir, drain all the PS fluid out...then simply refill with the new stuff.
Does that sound like it work without leaving bubbles in the lines or reservoir?
Thanks guys, I really appreciate it. I just got done with all freaking 16 spark plugs, and would like to get the PS fluid done today. Thank you!
JM
Old Oct 11, 2008 | 03:02 PM
eaglestorm's Avatar
eaglestorm
after I change a steering gear it takes 1 qt to refill the sys There is some fulid in the new gear not much and the res and lines are empty . 1 qt atf+4 if you drain the res and refil it do that 2 or 3 times to get whats left out of the gear. run the whell left to right 2 or 3 times then ck the fulid any air in the systen will bleed it self if the fulid is foamy let it sit it will clear up
Old Oct 11, 2008 | 05:51 PM
johnmichael
Well, thanks for the replies...I finally just went and did the flush, here's what I did. I have a 1 Pint fluid sucker that I used to drain the PS reservoir. I then refilled it with 1 Pint of new PS fluid. I cranked the truck and rolled the wheel back and forth to mix the old and new PS fluid.
I then did the above steps another 5 times, removing and adding the new fluid each time until I believe most of the fluid in the PS system is now new.
I topped it off, checked the level, and here I am...
Do you guys think that'll be good enough for a PS flush?
JM
