Best CAI
Old Oct 7, 2008 | 09:43 AM
uspatriot's Avatar
uspatriot
Default Best CAI
What is the best cold air intake system that will not void the warranty? Is it worth spending $360 for the Mopar one, or is there a better one out there?
Old Oct 7, 2008 | 01:12 PM
Geed's Avatar
Geed
I'm not sure which one is the "best" but I was looking myself and ended up ordering the Airaid one. It was a toss up between that one or the K&N. The Airaid seemed to be of better quality so I went with that one. We'll see.....
Old Oct 7, 2008 | 03:02 PM
asphaltman's Avatar
asphaltman
Question cai
i am looking to hear alot about ramhammer can"t find where to get one , and i don"t know about one for 08 hemin 5.7 2/wd that what i got ,mabe somebody well help us
Old Oct 7, 2008 | 04:03 PM
lxman1's Avatar
lxman1
Site Moderator
06-08 are the same. I'm just going to use my stock replacment K&N filter and order an AirRaid MIT tube. The stock box flows plenty of air. It's the HEMI hat over the throttlebody that has the restriction.
Old Oct 7, 2008 | 05:29 PM
MDSBigPaPa's Avatar
MDSBigPaPa
I chose the APM Ram-Air Hood, airbox w/K&N filter upgrade. http://www.ramairhood.com/ram_air_system_comparison.htm Why? I like the look but its cost is 5x the Mopar? Considering what it does, with my combo the air intake temp (measured with SC Flashpaq) is within the noise (1 or 2 degrees) of the overhead console ambient temp. I measured a buddy's under-the-hood CIA and the air intake temp was 25 deg F warmer than the ambient temp which is still probably cooler than the stock airbox.
Old Oct 7, 2008 | 08:20 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
+1...that's what I did and it turned out pretty good. I went with an Amsoil filter though...
Old Oct 7, 2008 | 08:32 PM
RaiderJay6's Avatar
RaiderJay6
Ram Hammer production is on hold for a while but it is an awesome piece of craftsmanship.
Old Oct 7, 2008 | 08:49 PM
dazed01's Avatar
dazed01
That looks pretty cool there
Old Oct 7, 2008 | 10:31 PM
lxman1's Avatar
lxman1
Site Moderator
Looks heavy and the metal holds heat. Just my opinion on those.
SeVeReDiStOrTiOn, Did you notice any power or mileage increases with the MIT/filter addition? I'm sure the sound is better, just wondering if it is really worth the $110 for the MIT?
Old Oct 8, 2008 | 12:24 AM
SeVeReDiStOrTiOn
The mid-high rpm pull is smoother...so there's definitely better airflow and probably some gain. At first I lost a few mpg but I didn't do a pcm reset, after a couple tanks the mpg is back to where it was.
