tow/haul mode better acceleration
Old Oct 6, 2008 | 07:53 AM
uspatriot's Avatar
uspatriot
Default tow/haul mode better acceleration
If you put tow/haul mode on do you get better acceleration?
Old Oct 6, 2008 | 11:07 AM
TANKZ400's Avatar
TANKZ400
I think so but maybe its just me.
Old Oct 6, 2008 | 02:04 PM
SHNOOL's Avatar
SHNOOL
I am new to my truck, and to this forum... I noticed it shifts at higher RPM's by default... so yeah quicker... But then, if you really trounce on it... it'll still stand up!
Old Oct 6, 2008 | 04:34 PM
lxman1's Avatar
lxman1
Site Moderator
Part throttle shifts are higher, I've seen no added power.
Old Oct 6, 2008 | 06:36 PM
The Bull's Avatar
The Bull
YES you get later shifs because in drive you loose RPM's due to the torque
Old Oct 6, 2008 | 08:07 PM
uspatriot's Avatar
uspatriot
so would it be better acceleration from a dead stop or moving? Also i remember one of my older cars said turn overdrive off if you need more power to pass someone. Is tow/haul the same thing as turning overdrive off?
Old Oct 6, 2008 | 08:24 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
O/D off doesn't allow the OD 4th gear...tow/haul does.
Your part throttle acceleration will be a little better in tow/haul because of the raised shift points...which results in higher rpms under the same amount of throttle. If you go WOT there won't be a difference...full throttle has it's own shift tables which aren't effected by tow/haul.
