signal light problems
Old Nov 17, 2008 | 09:37 PM
sheldon688's Avatar
sheldon688
it fixed itself somehow
Old Dec 2, 2008 | 11:48 PM
sheldon688's Avatar
sheldon688
aha and its back
well it sounds like it is the signal stalk by what happened to you, any idea on how much those run for?
thanks guys
Old Nov 16, 2009 | 11:49 PM
green@3d's Avatar
green@3d
Default it's not just me
ah ha
I thought i was going crazy!! I have been having this "signal right truck signals left, signal left, no signal at all, turn on the hazards, and then I get left signal," Bullsheit.. good grief..
So has anyone cured this problem without throwing a pile of parts at their ride?
I am wondering if there is a calibration the dealer can do to refresh the pcm?
I am almost wondering if it isn't a rubbed wire in the dash though, if I clunk the tilt down, it usually fixes the problem for a second or two.
Any suggestions.
Thanks.
06 1500 Mega Cab 5.7
06 Charger RT
Old Nov 17, 2009 | 11:27 AM
uspatriot's Avatar
uspatriot
Just buy a new truck, that should do the trick
Old Dec 2, 2009 | 06:37 AM
jumbonas's Avatar
jumbonas
anyone figure this out? same thing is happening to me now 06 QC... left=right right=right, turn on hazards to get left.
Old Jan 3, 2010 | 12:21 AM
green@3d's Avatar
green@3d
Cool It's baack.
I kinda forgot about it for a while. If I set the tilt just right I got no problem. Makes me suspect I got bad wire in the harness near the tilt pivot. I will pull it apart and advise as soon as I get some decent weather. been livin with -30 -40 b.s. latley.
Old Jan 3, 2010 | 03:32 PM
lxman1's Avatar
lxman1
Site Moderator
Multi-function switch.
Old Jan 27, 2010 | 08:36 PM
jumbonas's Avatar
jumbonas
does anyone have a part number?
Old Jan 29, 2010 | 09:13 PM
jonwv's Avatar
jonwv
I have an 06 QC... same problem....one dealer told me that they reset the Totally Integrated Power Module (TIPM) to solve the problem.
I call BS on the multi function switch. Mine did it last winter for 4 monthes, then mysteriously quit for 8 monthes, now about december it came back.....Can't prove that its weather related, but I think it is.
Old Jan 29, 2010 | 11:05 PM
WALLEYE HUNTER's Avatar
WALLEYE HUNTER
Default turn signals and running lights
My turn signals, and wipers also malfunction. i just lost rear running lights and license plate lights 2 nights ago. brake, turn and hazzards all work. checked all bulbs and fuses all ok. put in new turn signal (switch)modulator in the steering collumn, not the fix. Then put in new front modulator, not the problem. master fuse has power, but 3 mini fuses have no power, the relays work in either place so assuming they are both good. We dont have any clue from here. loose wire or possibly a small part of fuse box no good ? is that even possible. Lastly does it matter to disconnect power to the fuse box before replacing the front modulator, we didnt cut power, just unbolted turned upside down took off old modulatoe and plugged in the new one. still no rear lights.
