Void my warranty?
Anything you do to your truck, that Dodge can prove led to the failure of a stock component will void your warranty.
Example.... You level the truck. You have an issue with your front suspension or drive train if a 4x4.... They could say the leveling kit led to the failure. However... You level your truck and you toss a rod bearing. That is covered
They can't void your warranty because you replaced parts unless they can PROVE that what you did caused the other parts to fail. If you replace suspension components, obviously the new parts would not be covered under the warranty, but that doesn't mean that if your alternator died they wouldn't have to cover it. The Magnuson-Moss Warranty Act is the law that prevents them from covering you.
It could also depend on the dealership you deal with! The one I deal with is in a small community and they won't turn me away regardless! The service manager said he wanted to do to his truck what I have done to mine! They don't blink when I bring it in! If you are in a Large city where they don't (need) your business then they might be more by the book!! But all warranty work is reimbursed by the manufacture.
