Comp 260 cam on a pretty much stock 5.7 hemi?
Old Oct 13, 2008 | 09:18 PM
~RAM~'s Avatar
~RAM~
Default Comp 260 cam on a pretty much stock 5.7 hemi?
Would this be safe or unsafe?
an if i should need any other parts could i plz get some input?
thanks.
Mods include, LT headers, flow master super 40 exaust, k&n intake, Power wire, an on the say super chips flash paq
~mitch.
Old Oct 13, 2008 | 09:25 PM
HammerZ71's Avatar
HammerZ71
Real good cam, but you should look into the KRC210, little better HP gains, pretty good bit more torque. I've been planning the mod for over a year but ran into $ issues, I'll have it before too long.
You should at least do retainers and springs as well...
Old Oct 13, 2008 | 09:30 PM
~RAM~'s Avatar
~RAM~
ill check into it.. i appreciate it..
i also hear u might as well get heads if ur gonna put a cam in? should i jus hold off an save an get both.. or will i get a decent gain an lope wit jus the cam? im impatient...
Old Oct 13, 2008 | 09:50 PM
HammerZ71's Avatar
HammerZ71
With really aggressive HP Cams you would need heads. The Comp 260 and KRC210 are designed more for heavier trucks, especially quad cabs and 4x4's where more low end torque is much more beneficial to high end HP. So with either of those Cams, heads are not necessary.
You'll get awesome lope if you get an SCT tuner and have a custom tune written specifically to give you that really good lope.
Old Oct 10, 2020 | 05:08 PM
Domanick Gilman's Avatar
Domanick Gilman
I have a 04 2500 hemi and I have a 260 cam I’m doing but what springs and things should I get for the heads?
Old Oct 10, 2020 | 06:07 PM
The ones recommended by the manufacturer. Likely gonna need a custom tune as well.
Old Oct 10, 2020 | 07:11 PM
Domanick Gilman
what do you mean by the manufacture I got a comp cam 260 the specs are: Basic Operating RPM Range:1,000-5,500
Intake Duration at 050 inch Lift:208
Exhaust Duration at 050 inch Lift:212
Duration at 050 inch Lift:208 int./212 exh.
Advertised Intake Duration:260
Advertised Exhaust Duration:264
Advertised Duration:260 int./264 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.522 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.525 in.
Valve Lift with Factory Rocker Arm Ratio:0.522 int./0.525
how would I go about to get the heads built from this. I’ve never done this before
Old Oct 10, 2020 | 07:48 PM
Comp cams will have spring/retainer/lock recommendations. (possibly listed under 'recommended additional parts', or some such)
Is it this one? If so, please note where it says: "Slight tuning modifications and programmer required."
For the springs and such, I would suggest calling them, and asking. My guess is, the stock springs aren't good for that much lift. But, that's only a guess.
Old Oct 10, 2020 | 10:50 PM
Domanick Gilman
I found the springs to work for the cam-
Trick Flow® by PAC Racing Beehive Valve Springs TFS-16918-16. Should I need anything else besides the springs?
Old Oct 10, 2020 | 11:17 PM
cruzer55's Avatar
cruzer55
Yes to all of the above,And degree the cam.The follow the dots just don;t cut it for max performance.Just a thought...................
