throttle body cleaning
Old Oct 19, 2008 | 11:13 PM
uspatriot's Avatar
uspatriot
Default throttle body cleaning
Iwent to clean the throttle body this weekend and idk if your supposed to clean behind the flap, but when i pushed it in and wiped inside the rag came out with like a black grease. I just left it and hooked the intake back up for now. Is this normal?
Old Oct 19, 2008 | 11:45 PM
irelandshemi's Avatar
irelandshemi
mine didnt have a black grease it had like a brownish and i just put it back with no problems
Old Oct 19, 2008 | 11:57 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Grease or carbon? The cleaner mixed with carbon can make a greasy looking residue..
Old Oct 20, 2008 | 02:53 AM
abarmby's Avatar
abarmby
I agree with SeVeReDiStOrTiOn on the greasy residue due to solent interaction.
Either way, you must get rid of all that gunk to fully clean your TB.
Not only that, but reach down into the intake, being EXTREMELY careful not to drop anything in there, and wipe away until clean as well.
Use a small tooth brush to remove stubborn deposits and take the cleaning solvent to the rag/brush and DO NOT spray all over the TB liberally. This stuff can and will screw the electronic module on the end of the TB. Gently push the blade open so you can clean all around the blade edges.
Always ALWAYS keep the black electronic module upmost to avoid solvent leaking into it.
Also, when finished, do a TB calibration.
Switch the truck to ignition on then press the gas pedal 5 times fully down and up in sec intervals.
This tells the PCM where the TB fully closed/open is.
Hope this helps?
Al.
Old Oct 20, 2008 | 05:58 AM
BEAR's Avatar
BEAR
so you don't have to take the tb off to clean it?
Old Oct 20, 2008 | 08:22 AM
CarGuyOhio's Avatar
CarGuyOhio
I recommend taking it off as I did before. Then you can spray the cleaner in and the gunk you refer to will roll off. No to mention you can spray from the back side of the TB. Once again this is why your should take it off.... It is 4 bolts, 4 minutes of time.
Old Oct 20, 2008 | 10:02 AM
uspatriot's Avatar
uspatriot
So you pull this whole piece off http://estore.websitepros.com/stores...tle%20Body.JPG
Old Oct 20, 2008 | 10:04 AM
CarGuyOhio's Avatar
CarGuyOhio
Correct, if I recall 4 bolts, sensor cable and the throttle cable. Take less than 5 minutes to pull off.
Old Oct 20, 2008 | 10:06 AM
uspatriot's Avatar
uspatriot
Thanks, also what type of cleaner do you use?
Old Oct 20, 2008 | 10:59 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
throttle body cleaner, available at any parts store. i hear carb cleaner can mess stuff up, so get TB cleaner.
