03 5.7 dies at idle
Old Oct 25, 2008 | 08:38 AM
Glee's Avatar
Glee
Default 03 5.7 dies at idle
I have a 03 ram slt 4x4 5.7L
the problem i have had is while at idle speeds it dies.
I have only seen it die 2 times and my wife said it did it to here 2 times.
up till now it would die and we would restart it and it would act fine.
this last time we drove about 100miles round trip was fine i eased the truck in to park it at the house and it died, i started it right back up and it ran realy ruff it died again, i had to keep feathering the throttle to keep it running. i sat there awhile
i let off the throttle it ran kinda ruff then like nothing happend it ran smooth.
i bought this truck a month ago so i dont know what was done to it.
the only thing i have done was put in a K&N drop in filter.
i dont know if the heavy rain made it run ruff this time or what any ideas would be helpfull thanks.
btw i dont get any service engine lights or anything.
Old Oct 26, 2008 | 12:26 AM
rbrumm's Avatar
rbrumm
I ran my battery down once and could not get the truck to start w/o feathering the throttle. Once the battery gained charge it would idle back down and either die or idle fine. Dealer told me that it could have been the throttle position sensor. Since the battery died the throttle position sensor needed to reset. Just a thought.
Old Oct 26, 2008 | 02:06 AM
abarmby's Avatar
abarmby
My 03 does that somtimes.
It's only when you are shuttling between drive and reverse when parking.
At low/idle speeds, it suddenly starts to splutter and run rough.
Like it's running on only a few cylinders.
Feathering the throttle does nothing.
But like you said, if you leave well alone it sometimes recovers.
I also have to restart it if it doesn't recover as well.
After that, all seems well again and she runs as smooth as ever??
I think there is a flash for this?
But not sure?
Al.
Old Oct 26, 2008 | 03:34 AM
Stunnerguy's Avatar
Stunnerguy
Mine was doing the same thing, So I took off my intake to look at the throttle body and it was covered with crap. So I disconnected the batt. took off the TB cleaned it and it's been fine ever since...
Old Oct 26, 2008 | 08:34 PM
Glee's Avatar
Glee
thanks for the input guys. i put the stock air filter back on to see if it helps if it dont i will try some of the stuff you guys said thanks again
Old Oct 27, 2008 | 03:43 PM
Ilovemytruck's Avatar
Ilovemytruck
Had the same problem with my 4.7L ram, had my TB cleaned $65.00 @ the stealership and they replaced my Idle Air Control Module under warranty. Never had the problem again. Hope this Helps............
Old Oct 28, 2008 | 12:18 PM
HemiLonestar's Avatar
HemiLonestar
Hmmm....I have never had this problem....
Old Oct 28, 2008 | 01:18 PM
KrazyBrian's Avatar
KrazyBrian
Sounds like the idle air controller, It's mounted on the top of the throttle body
Old Oct 28, 2008 | 02:56 PM
Jkidd0223's Avatar
Jkidd0223
Default Dies
Yeah sometimes of '04 will just die at idle like going from reverse to drive when i back out of my driveway
Does anyone know the exact problem
