ohhh nooo
Old Oct 27, 2008 | 09:53 AM
Ben D.'s Avatar
Ben D.
Default ohhh nooo
Started the truck up this morning and the MIL light came on. IDK what it could be truck seems to be running ok. the light was flashing like a turn signal so i decided to call the dealer. They told me since the light is flashing driving it is a no go. they will be sending a roll back out to take it in to the dealer. I don't know guys this isn't good only 6.5k miles and problems already.
Old Oct 27, 2008 | 07:24 PM
lxman1's Avatar
lxman1
Site Moderator
It is seeing a problem when it is flashing. After it sees it for so long, then it will stay on steady. It probably wouldn't hurt to drive it, but since towing is free under the 3yr/36K warranty, mine as well use it
Old Oct 27, 2008 | 08:38 PM
Ben D.'s Avatar
Ben D.
well idk why it was flashing i pulled the code before the dealer came to pick it up this morning.... p050D cold start rough idle..... really? doesn't sound like a big deal. hoping just a reset of the PCM will do the trick but we shall see. they are gonna look at it tommorrow and call me. no rental atm. didn't ask for one since i didn't need it so i'll update tommorrow.
Old Oct 27, 2008 | 08:46 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Usually a flashing CEL means a misfire..
Old Oct 27, 2008 | 10:47 PM
Ben D.'s Avatar
Ben D.
yea kinda figured it'd be worse but that's the only code i was able to pull from it. did the on off on off on thing with the key and that's the code she read out.
