synthetic oil ?
Old Oct 29, 2008 | 07:32 AM
ramhunter9's Avatar
ramhunter9
[QUOTE=HammerZ71;1441053]Should have had a full tune up at 30k, did you do one?[/QUOTE
i bought it from dealer at 30k so im not sure if it was done prob. not knowing dodge dealer.
how hard it changing the plugs and what plug would be the best
Old Oct 29, 2008 | 08:08 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
[QUOTE=ramhunter1;1441330]
The plug change is not hard, just more time consuming than a normal 8 plug change. I used the standard replacement plug and have had no problems. Some people have tried platinum plugs with mixed results.
Old Oct 29, 2008 | 02:35 PM
ramhunter9's Avatar
ramhunter9
[QUOTE=Off_Road_Teacher;1441337]
any other recomended plugs???
Old Oct 29, 2008 | 05:21 PM
HammerZ71's Avatar
HammerZ71
Because the Hemi calls for them every 30k and nobody is reporting any better performance (often worse) with the higher end plugs, stick with the standard copper plugs, Champions seem to do as well/better than any...
Old Oct 30, 2008 | 12:34 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by damquick1
I have the 4.7, regretfully I had to switch back to conventional, I was using the Mobil1 full syn and lost 2-3 mpg in the city and a steady 3 on the highway. I tried three different times with the same results. I'm sticking with the Valvoline I'm running now. I'm back up to 18-19 mpg in the city and 23-25 hwy.
That's hard to believe! however, my mileage in my '08 5.7L did seem better and then all the sudden got worse. I changed my oil to synthetic my first oil change at 830miles. I was getting 13 all day in city even jumpin on the gas often. Now I have 1900miles and only get 11.5-12 going easy in the city. It's always said that synthetic yileds better mileage because it's lubricity or whatever you call it. I know it's way to early to start even getting used to a certain MPG because it's premature stage for break-in period, but Man you got me thinkin lincoln...haha
Old Oct 30, 2008 | 03:03 PM
Ilovemytruck's Avatar
Ilovemytruck
I Have a 4.7 I use Iridium plugs. (NGK) bought them at advanced auto. Used platinum but I really think my MPG went down after installing them, so I went to Iridium.
Man thats some good MPG for a 4.7L.
I think I used to get 15.1 in the city 22/23 in the highway at approx. 65MPH which I no longer do.
Old Oct 31, 2008 | 05:26 PM
froto'sride's Avatar
froto'sride
i used the platnium duel spark and they have robbed me but i have yet to change them. I do however use the mobile1 synthetic and have had no problems with it other than the cost. I did start using that ZMAX stuff and it has increased my millage by 2mpg and i have only used it once
Old Oct 31, 2008 | 07:29 PM
ramhunter9's Avatar
ramhunter9
well i went with the mobil 1 synthetic so we will see how it does. plugs are next thinking of champions
Old Nov 1, 2008 | 12:39 AM
lxman1's Avatar
lxman1
Site Moderator
Winter blends of fuel usually get worse mileage is why it suddenly dropped!!
Old Nov 2, 2008 | 01:33 AM
Powerubi Wacon's Avatar
Powerubi Wacon
I will only use synthetic oil. Mobil 1 is my choice. My Ram gets 5W-20, my Grand Cherokee, and Wrangler get 10W-30. My Mustang (over 225,000 miles) gets either Valvoline Dura-Blend or Castrol Syntec-Blend semi-synthetics. They ALL get WIX filters!
My Grand Caravan is a company vehicle so it gets whatever the dealer puts in.
