Radiator
Old Nov 3, 2008 | 06:39 PM
04 HEMI 04's Avatar
04 HEMI 04
Exclamation Radiator
Hello Everyone,
I am writing this up to tell you that a friend of mine found out the my radiator is no good. I found out why my truck have leaking too much anti-coolant and I don't know what to do about the radiator. Should I replace it or buy an aftermarket radiator for hemi? Should I replace the radiator along with 180 thermostat?
It is very important that I need your help immediately because I am going on a trip from CT to Florida in the next three days with a boat. I need to get the radiator fixed or else it will overheat. Thanks.
Any advices or help would be greatly appreciated.
Old Nov 3, 2008 | 10:51 PM
jstmahoney's Avatar
jstmahoney
I would do a OEM replacement.
Old Nov 3, 2008 | 11:05 PM
lxman1's Avatar
lxman1
Site Moderator
New radiator and use a 195 thermostat.
Old Nov 4, 2008 | 09:09 AM
HemiLonestar's Avatar
HemiLonestar
What is anti-coolant? Does it keep it from cooling?
Old Nov 4, 2008 | 12:13 PM
04 HEMI 04's Avatar
04 HEMI 04
thanks guys but i have another question where would i find the radiator and the 195 thermostat? What kind of anti coolant should i use for hemi?
Thanks
Old Nov 4, 2008 | 02:44 PM
JeffBea's Avatar
JeffBea
I think the stock radiator fluid is the red stuff. If it's red in yours that's what i would put back in it.
Old Nov 4, 2008 | 03:05 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
go to an autozone, pep boys, murrays, most any of them should have a radiator for you. 190 degree thermostat, 195 degree thermostat, whatever, they'll both work fine. refill with whatever color coolant comes out of it like jeff said. make sure you use deionized water when you mix the coolant 50/50 with water when filling, or you'll start building up gunk inside.
not to be an ***, but its called anti-freeze, or coolant, not both
Old Nov 4, 2008 | 03:24 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Antecedent?
