2wd vs awd
Old Nov 16, 2008 | 10:24 PM
mighty4's Avatar
mighty4
Default 2wd vs awd
so i am wondering if a 2004 dodge ram with the electronic controller for 2wd, 4wh, 4wl, has a different transfer case then one with awd option? If not what are the differences, i blew apart my front diff today and my buddy has the same truck as me but not the laramie version so he has 2wd on his drivetrain controller instead of awd, and i want to convert mine to not have awd to save my front diff from not being beat on when i dont need it to be but jsut trying to figure out what i would need to change it to not be awd when not in 4wd?
thanks
Old Nov 17, 2008 | 12:49 AM
dirtydog's Avatar
dirtydog
Moderate User
differnet gears probably. Also, the AWD has different internals all together (clutch packs...etc). It's meant to be in AWD all of the time. Taking turns in an AWD vehicle is far easier than in a 4wd "part time" vehicle. Any vehicle that has 2wd/4wd/4lo is called a "pat time"4wd. The AWD is fully engaged so it would be a "full time" 4wd. Not even the same.
Old Nov 17, 2008 | 06:16 AM
mighty4's Avatar
mighty4
so basically i would need a new transfer case to out of a 2wd one to make it work?
Old Nov 17, 2008 | 07:05 PM
mighty4's Avatar
mighty4
does anyone know anything on this site? I have asked many question and never seem to get any responses? Probably the first response i have ever got up there so far?? Thought these sites were made to be helpful to others?
Old Nov 17, 2008 | 07:27 PM
thehemiman12345's Avatar
thehemiman12345
I know awd was an option on these trucks but is it really all that common? It doesn't seem like too many members have it...
Old Nov 17, 2008 | 07:30 PM
Carrolls Ram's Avatar
Carrolls Ram
I believe programming in the PCM of an AWD is different than a 4x4 and the Tcase setup may be a little different
Old Nov 17, 2008 | 07:57 PM
dodge it then ram it's Avatar
Sorry dude. Most people probably dont have an answer. I know I dont have a damn clue.
Old Nov 17, 2008 | 11:54 PM
dirtydog's Avatar
dirtydog
Moderate User
It could just be the programming! My 2000 Silverado had an AWD along with 2wd/4wd/4lo. It had them all. In GM's scenerio, it utilized the 2wd mode until the ecu detected rear wheel slippage and instantly kicked in 4wd so to save on tires and gas and wearable drivetrain. If Dodge copied them and used the same thing, then it's simply a ecu program. Here's an Ebay link and they say nothing about it http://cgi.ebay.com/ebaymotors/02-03...spagenameZWD1V
Old Nov 18, 2008 | 12:24 AM
Carrolls Ram
Thats the way our 05 burban does it. With the ram though I remember reading it cuts alot of torque through torque management. The awd LX cars dont have as much get up and go as a 2wd one. Yes they hook but the PCM doesnt allow them the full power that they want.. Thank you throttle by wire and stupid *** PCM
Old Nov 18, 2008 | 12:33 AM
cyclone429's Avatar
cyclone429
I'm going out on a limb, AWD and 4x4 can't share the same transfer case, 4x4 and AWD are know where close to being the same, AWD's don't have a transfer case at all, just a center differential with drive shafts to the front and rear diferentials, in a part time 4x4, the transfer case is the center diferential.
