so called power wire
Old Nov 22, 2008 | 02:09 PM
  #31
lxman1's Avatar
lxman1
Site Moderator
Ok here's the deal.
Send me a free power wire for my 08 Hemi Ram. I will install it and give an honest, unbiased opinion on the product.
This way I won't lie to justify that I wasted $40 on something that doesn't work.
PM me for mailing address.
Old Nov 22, 2008 | 03:13 PM
  #32
codiac's Avatar
codiac
Not trying to be difficult, but what is the logic behind this? If it's so good, and so cheap, why doesn't Dodge just advance the timing to gain the extra horsepower? Is it MPG's, reliability, or something else? Something had to have the engineers @ Dodge set it the way they did, I'm assuming they didn't just overlook this.
Old Nov 22, 2008 | 03:44 PM
  #33
John  M's Avatar
John M
Dodge doesn't put the timing there by default so you can run lower grade gas. Since I run 93 octane all the time, I don't have any problems with the wire combined with my Superchips timing changes. Many people aren't willing to put premium in a vehicle that gets 10 mpg.
If you just installed a power wire and ran regular gas, the knock sensor would veto any timing advance and negate any gains. This is probably the central cause when people say "it didn't do anything".
Old Nov 22, 2008 | 03:59 PM
  #34
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by lxman1
Ok here's the deal.
I got mine for free so I have no reason to lie and I can tell you that it really does work. It gives a boost in power that you can feel and I saw the results in my 0 - 60 times as well.
Old Nov 22, 2008 | 05:04 PM
  #35
ivaskaj's Avatar
ivaskaj
I didn't notice any difference in power, but I'm never at WOT. I did however notice that my gas mileage doesn't drop quite as drastically in town as it used to. On another note, as soon as I installed it my overhead computer went from being dead on accurate to about 1 MPG optimistic. I don't get that.
Old Nov 22, 2008 | 11:54 PM
  #36
lxman1's Avatar
lxman1
Site Moderator
SHHHH!!! Man, I was trying to get a free one!!!! I can't afford one right now. Been out of work since August. Just got a job this week.
Old Dec 9, 2008 | 11:00 AM
  #37
ram-fjallasport's Avatar
ram-fjallasport
hmmm..
let me ask.
I have heard that it is possible to put a resistor in the wire-lomb to trick the temp sensor.
so I wonder witch wire to put this resistor to, and how manny ohm's is this resistor?
this is just a sensor so the watt don't need to be high, about 1/4Watt is enough.
I have not the locked into my RAM, but maybe there is only two wires to this sensor. Then there is just to know the resistor size!!!
is there anybody that want to inform the rest off us!
Old Dec 9, 2008 | 01:47 PM
  #38
whiteram05's Avatar
whiteram05
Now that all is laid out for us novices, I would like to add to the previous request. Can anyone tell us not only the resistor to use and the wire to tap into, but are there wire connectors that we can use in conjuction with the resistor to keep us from having to tap into the wire, or should we just spend the money and buy one? I have the 3.7 V6 but would love to try the power wire out!
Old Dec 9, 2008 | 02:28 PM
  #39
ram-fjallasport
ha....
I think I have fount this out!
the resistor can vary from 4,5-5 Kohm.
there is probably only two wire to the conector and witch one you cut and put the resistor in..... dont mather!
cause the resistor is in serial with the temp sensor!
Old Dec 9, 2008 | 03:10 PM
  #40
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Originally Posted by ram-fjallasport
ha....
correct. 5.5 KOhm, added in line with either wire going to/from the IAT sensor. instant 'powerwire' won't do much for you in the cold though.
