quick tire question
Old Nov 25, 2008 | 01:13 AM
irelandshemi's Avatar
irelandshemi
Default quick tire question
im ordering my terra grapplers in the stock 265/70/17 and when it asked to put in my vehicle to make sure they fit it didnt bring them up it brought up the 285/70/17, the 265s will fit right i have the stock 17s on an 03 quad cab and whats the inch size of the 265's
Old Nov 25, 2008 | 01:38 AM
dirtydog's Avatar
dirtydog
Moderate User
265 is metric for 265mm. The 285's are obviously wider by 20mm which will directly effect the height of the tire. I don't know what your factory tire size is? Maybe check the door tag and it will tell you but 285 sounds like a big tire from the factory?
that difference will show on your odometer.
285= 11.2" wide @70% aspect ratio=199.5mm sidewall(7.85")
Take the sidewall number of 199.5mm x2 =399mm
399mm=15.71"+ the rim height of 17"= 32.71" size tire
Now for the 265, I'll go quick. It's height is 31.61" size tire
Hope that helped
Old Nov 25, 2008 | 01:48 AM
irelandshemi
i have 265 on there now i was just wondering why it didnt bring it up as a fit for my truck
Old Nov 25, 2008 | 05:57 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
either will fit fine. the 285 will throw off your speedo just a little bit.
