3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
They didn't mention it because many of the parts on your chassis are so called "lubed for life" and are sealed, such as u-joints, ball joints, etc. In reality, the seals eventually break and water and dirt works its way into the grease and the part fails, but there is nothing you can do to prevent it other than replacing the part with an aftermarket part that can be lubed.
If you have a warranty and something goes, would you need prove that you changed the oil for example, if not changing the oil could have effected that part breaking?
